Need hint regarding Euler's constant question
  • Thread starter Thread starter librastar
    Constant
librastar
Show that Euler's constant is 0 < \gamma < 1
According to my book, \gamma = lim((1+1/2+...+1/n) - log n) as n approaches infinity
At first glance I was thinking about proving by contradiction.
First I assume \gamma is equal to 0.
Then I will get lim(1+1/2+...+1/n) = lim (log n) as n approaches infinity.
However 1+1/2+...+1/n is a harmonic series which diverges, so the equality does not hold.
So \gamma does not equal 0.
Next I assume \gamma is less than 0.
Since log function never yields negative result, this implies that lim(1+1/2+...+1/n) < lim(log n) as n approaches infinity.
Again due to the divergent nature of harmonic series, the inequality does not hold.
These are all I have for now.
I feel I have logic error in the attempt to solve the problem, and I hope that someone will give me a hint on the correct solution.
Keep in mind that
\lim_{x\to a} [f(x)-g(x)]=\lim_{x\to a}f(x)-\lim_{x\to a}g(x)
Is only true if both the limits on the RHS exist.
I haven't tried the problem yet, but you might consider using the squeeze theorem.
For proving the positivity of \gamma you should think about Riemann sums
just to add to you first post, log(n) also diverges, so the harmonic argument doesn't quite hold
Same for showing it is less than 1. Very simple and nice when you see the idea.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
