Need some help on this question
  • Thread starter Thread starter sstudent1
The problem involves two particles on the x-axis, with one having mass m at the origin and the other having mass 2m at x=+L. The objective is to determine the position of a third particle such that the gravitational force on both existing particles is doubled, expressed in terms of L.
  • Participants discuss the gravitational forces acting on the particles and how to incorporate the third particle's influence. There are attempts to set up equations relating the forces before and after the addition of the third particle. Some participants express confusion about the relationships between the forces and the positioning of the third particle.
Multiple interpretations of the problem are being explored, with some participants suggesting different placements for the third particle and others attempting to derive equations based on the forces involved. There is no explicit consensus, but several lines of reasoning are being developed.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also mention of differing mass assignments for the third particle, which adds complexity to the discussion.
sstudent1
Two particles are located on the x axis. Particle 1 has a mass m and is at the origin. Particle 2 has a mass 2m and is at x=+L. Where on the x-axis should a third particle be located so that the magnitude of the gravitational force on BOTH particles 1 and particle 2 doubles? Express your answer in terms of L.
F = G(m1)(m2)/(r^2)
I know ur suppose to us the above equation.
I have found the F between particle 1 and 2 to be = (G)(2(m)^2)/(L^2) and the F between 2 and 1 is the same magnitude but negative. So then place particle 3 on the x-axis at point X. so then now i am kind of stuck. Is the new force of particle 1 with the addition of particle 3 equal to = F btwn. particle 1 and 2 + F btwn. particle 1 and 3.
edit: also i assigned the mass of particle 3 as m2. So the mass of particle 3 is different then of particle 1 and 2.
Any help will be appreciated.
I think you would get something like:
[tex]{F}_{on\_A}={F}_{AC}+{F}_{AB}[/tex]
[tex]{F}_{on\_B}={F}_{BC}+{F}_{AB}[/tex]
[tex]{F}_{on\_A}=2\,F[/tex]
[tex]{F}_{on\_A}={F}_{on\_B}[/tex]
kinda that
Ok yeah so u set 2F = Fac + Fab. But doesn't the Fa = Fab. The force between particle A and B (1 and 2). Rite?
A=1
B=2
C=3
rite?
mmm rootX left mre more confused then before! help!
Before:
The gravitational force acts on 1 and 2 are the same = x
After:
The gravitational force acts on 1 = The gravitational force due to 3 AND 2. = y
The gravitational force acts on 2 = The gravitational force due to 3 AND 1. = z
Therefore :
y = 2x AND z = 2x since the new force acting on both the particles 1 and 2 are doubled of before.
Answer: -L plus minus (square root of 2) *L ( if i am on the right track)
Leong said:
Before:
After:
Therefore :
ahh no i don't think so. the book says the answer is .414L but i don't know how to get it ...
any help guys
yep, I got it! :D
so, using the information provided, you will end up with:
F(between A and C) = F(between A and B)
I didn't simplify further in the previous post, and above is what you get after further simplications.
and, C can be to the right of B, or inbetween A and B, or to the left of A.
Case I:
C----A----B
Case II:
A---C-----B
Case III:
A----B----C
you know mass of A=0.5 times mass of B,
and net force on A is equal to force on B,
and now, find thr right case, and solve the problem!
think of electric charges, and that static electric forces, if you are good at them
Before:
The gravitational force acting on the 1 and 2 are the same:
[tex]F_{initial}=\frac{Gm*2m}{L^2}[/tex]
After: Let's assume that particle 3 is put between 1 and 2 and is +y from the origin and its mass is m3.
Then,
The gravitational force that acts on 1 = The one due to 2 AND 3.
Since 2 and 3 are at the right of 1. 2 and 3 will pull 1 in the same direction which means the gravitational force that acts on 1 is the SUM of the two gravitational forces due to 2 AND 3.
[tex]F_{1}= F\ due\ to\ 2 + F\ due\ to\ 3[/tex]
[tex]F_{1} = \frac{Gm*2m}{L^2} + \frac{Gm*m_{3}}{y^2}[/tex]
[tex]But\ F_{1} = 2*F_{initial}, therefore,<br /> <br /> \frac{Gm*2m}{L^2} \ + \frac{Gm*m_{3}}{y^2} = 2*\frac{Gm*2m}{L^2}[/tex]
Simplify:
[tex]m_{3}=\frac{2my^2}{L^2}[/tex]
Repeat the same thing for F2, at the end, you will have two equations in terms of m3 and y. Then solve for y. The one above is one of them.
Leong said:
Before:
Then,
Simplify:
ok yeah thx. at the end i get 2y^2 = (L-y)^2. How do i solve for y?
edit: nvm i got it. Thx for the help!
