Need some help with finding the 2nd moment of area
  • Thread starter Thread starter jsharma
    Area Moment
The discussion centers on calculating the second moment of area for a T-beam, with specific measurements provided. The user has calculated the moment of inertia for both the upper and lower rectangles of the beam but suspects an error in their calculations, as the theoretical maximum bending stress significantly differs from practical results. They report a theoretical stress of 3.4*10^8 compared to a practical measurement of 81.45*10^13 for a bending moment of 84 Nm. Participants suggest that the discrepancy may arise from confusion between units, particularly with the bending moment value. The conversation emphasizes the importance of accurate calculations and unit consistency in structural analysis.
jsharma
hi I am having trouble with findin second moment of a T-beam.
here are the measurements of the beam:
http://img354.imageshack.us/img354/8648/beam6xl.jpg
I have found the neutral axic fro the beam
and tht is 11.943 mm from the bottom rectangle
for 3nd moment of area
i have separated the two rectangles and calculated for each
Ixx= (6.4*(31.7)^3)/12+6.4*31.7*(10.4)^2 for the upper rectablge
Ixx= (38.1*(6.4)^3)/12+6.4*38.1*(8.65)^2 for the bottom rectangle
Then i added both and i got 5.8*10^-8 m^4
Then i had to find out the maximum stress for maxmimum load i.e for 84 Nm
i used the formula Stree= bending moment * neutral axis maximum/ 2nd moment of area
when i calculate it i don't get the same value as done in the practical i gues there is something wrong with my calculation in Ixx so please can you tell me wht am i doing wron here
I get your same results if I ignore whatever those solid filled rectangles are supposed to represent.
thnnx well the another thing was that does the bending equation accurately predict the stress in the beam
It predicts the max bending stress at the outermost fibers (top) of the beam based on the moment in the beam at that point.
I have done a practical in the beam, well i got the same neutrl axis in the practical as in the theoretical but when i go and find the maximum bending stress i get 3.4*10^8 theorretically but in practical it is 81.45*10^13 for bending moment 84 Nmm. is it alright wht am i doing wrong here
Between mm and meters you've lost me with the decimal point. But perhaps your error is in the value of the max bending moment of 84n-m (or 84 n-mm). Where'd that number come from??
