Need to simulate different wattages
  • Thread starter Thread starter Physicslearner500039
The discussion revolves around simulating different wattages for an embedded board that drives various loads at 24V. The board's software cuts off the output voltage when no load is connected, preventing the desired 24V output. The user seeks a method to simulate load without physically connecting the actual devices, as there are around 30 outputs to manage. Suggestions include using resistive loads or power resistors, but concerns arise regarding the effectiveness of this approach. The user ultimately needs a solution that allows the interface board to draw sufficient current to maintain the 24V output for testing purposes.
Hi all,
i have an embedded board which is capable of driving loads of different wattage(75W, 21W lamps etc) at 24V using some driver Integrated Circuits. The embedded board is programmed in such a way that the output is cutoff (there is no 24V output) when the loads are not connected. Now i want to simulate the different wattage using a hardware circuit without actually connecting the loads since there are around 30 outputs. I am actually trying to get 24V output and display it on the personal computer that the particular load is ON based on some input switch condition but i am not getting 24V now as no load is connected. Could somebody give me some idea how to proceed. please let me know if i am not clear.
Thanks and regards,
Satya
You want all outputs loaded simultaneously? Something like a resistor from each output to ground? They would have to be power resistors, and the cheapest are usually light bulbs. What is the minimum load that should be recognized? You could try 5 watt power resistors, maybe even overload them 100% for 5 or 6 seconds. A 100 Ohms resistor would dissipate about 5 watts of power. The resistors will get hot.
Not sure what you mean by this. It seems contradictive to me.
sorry i was not very clear in my explanation. now i have attached a picture.
1. The embedded board is having a software program running in it and the purpose of the board is to switch on loads like lamps of different wattages(75w, 21w etc) at 24V in the field.
2. My aim is to validate the software that is to verify whether the program is properly switching on the loads when the corresponding switch is switched ON on the bench before actually going into the field.
3.For that i have designed an interface board which would simulate the switches by giving 24V/0V with the control from the personal computer and read back the outputs from the embedded board into the interface board. If 24V is coming into the interface board i assume the load is switched ON and the same would be displayed on the PC.
4. The problem now is the software in the embedded board has been written in such a way that it would give 24V to the load when a switch is ON but in case no current is drawn from the particular load then it would immediately make the voltage to some 5V. My problem is that since the interface board is not drawing any current the embedded board software would immediately cutoff 24V. my interface board cannot withstand more current so i want to introduce one more interface circuit which would draw different and required currents so that it gives out 24v which i can read through the interface circuit and display on the personal computer(All the loads may not be ON at the same time).
Hope it is clear.
thanks and regards,
satya
Sorry satya77, if anything it is now less clear.
Apparently a resistive load isn't going to be a solution
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
