Negative Charge Stability: Oxygen vs. Carbon/Nitrogen
The discussion centers on the stability of negative charges in different molecular configurations, specifically comparing the stability of negative charges spread over oxygen atoms versus carbon and nitrogen atoms. Participants explore concepts related to electronegativity, hybridization, resonance, and acidity in organic compounds.
  • Some participants propose that a negative charge is more stable when spread over multiple oxygen atoms compared to being localized on carbon atoms, potentially due to differences in electronegativity.
  • Others question at what point hybridization of carbon atoms can stabilize a negative charge better than more electronegative atoms like nitrogen.
  • A participant suggests that the electron affinity of O2 is higher than that of C3O, and similarly for O3 compared to NO, indicating a possible relationship to the stability of negative charges.
  • There is mention of specific examples from organic chemistry textbooks that illustrate exceptions to the ARIO rule, prompting further exploration of acidity and stability.
  • Some participants note that resonance forms contribute to the stability of anions, with carboxylate and sulfonate anions having multiple resonance forms that stabilize negative charges more effectively than phenolate anions.
  • One participant highlights the role of hybridization in stabilizing negative charges, particularly the greater stability of the acetylide conjugate base compared to other carbanions.
  • There is discussion about the lack of a systematic reason for certain stability comparisons, suggesting that some aspects may need to be memorized rather than derived from first principles.
  • Quantum chemistry programs are mentioned as a means to calculate stability, but participants acknowledge the absence of simple heuristics for these calculations.
Participants express differing views on the relationships between electronegativity, hybridization, and charge stability. No consensus is reached on the specific conditions under which one factor outweighs the other, and the discussion remains unresolved regarding the best approaches to understanding these concepts.
Some participants note that the questions posed relate to specific examples that may not be straightforward and involve complex species that are not commonly encountered, indicating potential limitations in generalizing the discussion.
Zayn
Why is it that it is more stable for a negative charge to be spread over 2 oxygens than one oxygen and 3 carbon atoms? Following that logic, why is it more stable to spread a negative charge over 3 oxygen atoms than over 1 oxygen atom and one nitrogen atom? Is it because the difference in electronegativity is much greater between the oxygen and carbon than it is between the oxygen and nitrogen?
Chemistry news on Phys.org
Just to extend this idea, at what point does a hybrid carbon atom stabilize charge better than a more electronegative atom? For example, according to my textbook, an sp-hybrid C atom stabilizes negative charge better than a nitrogen atom. At what point does hybridization's effect overcome electronegativity?
It's clear that you have an example in mind, but for the life of me, I can't figure out what it is. I don't think you're asking what you think you're asking.
Here's what it appears you're asking: Why is the electron affinity for O2 higher than for C3O? and why is the electron affinity for O3 higher than for NO?
Is this what you're asking, or do you want to clarify?
EDIT: the reason I ask is because these are very strange questions about some very strange species (C3O in particular, which only really exists in outer space or maybe transiently in flames).
You're right, I'm asking about a specific example from my organic chemistry textbook, but I didn't want to say that as I'm not asking for homework help; I'm just wondering why this is the case. As I understand it, these questions are here as examples of exceptions to the ARIO (atom, resonance, induction, orbitals) rule learned in the textbook.
The question asks to determine which proton is the most acidic
Here is an imgur album that shows the questions with their answers
I’m still not getting how the problem you linked to in post 4 is related to the questions you asked in posts 1 and 2. If you want to know why a terminal alkyne is acidic, that’s fairly straightforward. It’s because the electrons in the sp hybridized orbital on the carbon are less shielded from the nucleus than in sp2 or sp3 orbitals (because of the higher s character). So the acetylide conjugate base is more stable than an alkenylide or alkylide carbanion. In contrast, the NR2- anion is quite unstable.
Why the amide is so much more basic than the acetylide, well, unfortunately that’s just something you’ll probably have to memorize. I don’t think there’s any systematic reason why that’s t he case. If it helps you to remember, the acetylide salt is usually made by combining an alkyne and an amide (e.g., acetylene + sodium amide gives sodium acetylide + ammonia).
In addition to the electronegativity difference, there is the fact that in the carboxylate and sulfonate anions there are 2 or 3 resonance forms that are identical (assuming free rotation about the ring-substituent bond), and therefore equal in energy and contributing equally to the resonance hybrid. By contrast, in the phenolate anion, the resonance forms with negative charge on carbon are of higher energy than the one with negative charge on oxygen, and therefore make less of a contribution to the overall resonance hybrid.
I understand that, but my question was more along the lines of: Why is an sp2 hybrid C less able to stabilize the charge than nitrogen, but sp is better than nitrogen (I understand the principle that hybrid orbitals are closer to the nucleus and thus better able to stabilize -ve charge); at what point is the effect of C hybridization > electronegativity. I guess it's just been experimentally determined to be so, and, as you said, it's something that should just be memorized. And as for the other two examples, I was trying to understand how charge spread over 1 O + 1 C + 1 C + 1 C < 2 O, but from what mjc123 has said, it seems like it's not something that be understood as an equation.
It can be calculated using quantum chemistry programs, but unfortunately, there’s no simple heuristic way to calculate it. Slater’s rules aren’t really much help, for example, in determining how shielded the excess electron is.
