Negative pressure from vacuum to shunt a object upwards?
The discussion centers on the concept of using negative pressure in a vacuum airship design to create an upward force for transporting goods. The proposed design features a cylindrical body with a wider bottom and a vacuum-sealed top, which, when the lid is removed, could theoretically experience an upward force due to atmospheric pressure differences. Two potential outcomes are outlined: one where the rig is propelled upward due to negative pressure and another where it simply shakes without any net upward force. The conversation emphasizes the physics principles involved, particularly Newton's laws and atmospheric pressure dynamics.
  • Understanding of Newton's laws of motion
  • Familiarity with atmospheric pressure concepts
  • Basic knowledge of vacuum technology
  • Experience with aerodynamics and buoyancy principles
  • Research the mechanics of vacuum airships and their design challenges
  • Explore the principles of negative pressure and its applications in engineering
  • Study atmospheric pressure variations and their effects on buoyancy
  • Investigate materials suitable for vacuum containment, such as carbon fiber
Aeronautical engineers, physics enthusiasts, and individuals interested in innovative transportation solutions will benefit from this discussion.
nightsdawnfan
Hi folks,
I think a lot about aeronautics and physics for the purposes of helping people. I stumbled across the idea of vacuum airships as a cheap method of transporting food and water to places where it's unsafe for vehicles, or where there are no roads. We all know it's unconventional and uneconomical to sustain a vacuum -- carbon fiber and specialized materials are expensive even if you have a working design. My next idea is the principle of negative pressure. For thought, just imagine a tall cylindrical body with two parts to it. The bottom is the place where you put things and the bottom face is wider than the top. The top is empty with walls thick enough to handle rapid changes in pressure and covered with a lid. The top portion is a envelope with vacuum. The whole thing is beaker shaped. Next, imagine this setup is lifted onto a crane above the ground to rest. At this point, "with the snap of a finger" let's make the lid disappear.
What would happen?
A) The rig is shunted upwards due to the negative pressure due to a momentary upward force.
* Atmosphere above fills the void
* Atmosphere underneath (at a higher pressure because it's lower relatively) pushes up to fill the void
* Rig experiences a net force upward force due to the negative pressure
* Newtons law allows the net up force because the higher pressure of air below relative to the void.
B) The rig just shakes up and down briefly
* The atmosphere above collapses on the void equal to the atmosphere below
* Result is no net up force even including for the momentary buoyant force
Thanks
Nightsdawnfan
I will work on one, will try for a post later tonight.
Thanks
Nightsdawnfan
  • · Replies 124 ·
15K
  • · Replies 27 ·
  • · Replies 27 ·
