B How Can I Calculate Negative Multiplication Without Following Traditional Rules?
The discussion revolves around calculating negative multiplication without adhering to traditional rules. A user presents a scenario of multiplying 6 pencils by negative two, concluding that 6 x -2 equals -6 based on their reasoning. However, others clarify that starting with 6 pencils means the equation should be interpreted as 6 + (-2 x 6), resulting in -6. If the initial count were zero, the outcome would be -12, emphasizing the importance of the starting value in calculations. The thread concludes with a reminder that the original post was deleted after receiving clarification, which is against forum rules.
pyroclasticsoul
Do NOT delete your Original Post after you have received replies and help
TL;DR Summary
Negative times positive
Say I have 6 pencils. I want to times this by negative two. Now ignoring the rules that your teacher taught you work this out. 6 pencils negative 2 times. Negative one time would be 0 and another negative times would be -6 right? So 6 x - 2 = -6 according to simple logic. The calculator will say -12 but if I took 6 away from 6 3 times that would be -12.
  • Skeptical
Likes PeroK
Mathematics news on Phys.org
pyroclasticsoul said:
TL;DR Summary: Negative times positive
No. You started out with 6. "I have 6 pencils." You're describing 6 + -2x6 which equals -6.
If you had started out with zero, then the final answer would indeed be -12.
Likes fresh_42
I thought about that but why do I start with 0 and not 6 since 6 is the number adjusted by -2.
Read the problem statement you wrote.
"I have 6 pencils"
The problem starts at +6 pencils.
Note -- the OP deleted their first post after getting help from Dave. This is not allowed. The OP text is restored and this thread is now closed.
Likes SammyS, Bystander and topsquark
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
