Net electric field question almost have it but can't get one part of it
3 replies · 6K views
itsagulati
Two charges, -26 µC and +5 µC, are fixed in place and separated by 1.3 m.
(a) At what spot along a line through the charges is the net electric field zero? Locate this spot relative to the positive charge. (Hint: The spot does not necessarily lie between the two charges.)
E = k*q/r^2
26e-6k / d^2 = 5e-6k / (1.3 - d)^2
i solved for that and got d = .9037 and d = 2.32 ...since i need them pointing in the same direction its the one that is not between them. i understand that...and it all seems right.
Does anyone get something different?
It is an odd #'d problem so i looked at the question in the book and was able to work it to get the right answers for the book version, but my online #s are different and while i work it very similarly and it all makes logical sense. I get them wrong :(
Any tips?
The question asks for the distance from the positive charge... so this is not 'd'... from your formula d is the distance from the negative charge...
Although your equation is technically correct... I'd advise first finding the region where the field is 0, then choosing your variable appropriately... There was a recent thread on this and Doc Al gave a great explanation.
I saw that and read it and hten posted this one. Based on what i picked up in that thread, I ended up with the above.
However, based on what you said I assume if we drew it out on a line...with the negative charge as our starting point...2.32m out would be what I said was the answer. However, since there is a distance from the negative charge to the positive charge of 1.3m...then 2.32m- 1.3m = 1.02m? Does this sound right?
Thanks!
However, based on what you said I assume if we drew it out on a line...with the negative charge as our starting point...2.32m out would be what I said was the answer. However, since there is a distance from the negative charge to the positive charge of 1.3m...then 2.32m- 1.3m = 1.02m? Does this right?
Thanks!
Yes, 1.02m is right. That's cool... I thought since you used (1.3 - d)^2 instead of (d - 1.3)^2, you were expecting d to be less than 1.3... both equations are the same...
As long as you know what's happening, it's all good.
