Network Maximum Power Transfer Calculation
70 replies · 11K views · last reply
Zth=(330.3+j219)
Zl=(330.3-j219)
shaltera said:
Zth=(330.3+j219)
Zl=(330.3-j219)
Okay, and how are they connected in the circuit?
shaltera said:
Znet=Zth+Zl=660.6?
Yes! :smile:
Note that the reactive components have completely disappeared. The choice for ZL as the complex conjugate of Zth has ensured that the reactive components cancel each other.
So for purposes of analysis at this point, the source impedance is just a real resistance of 330Ω, and the load impedance is just a real resistance 0f 330Ω. Two resistors! Easy to analyze!
Can you find the power in that load resistor? Remember that the source voltage is Vth.
That'll work; So how will you calculate the current? Remember, the load circuit now comprises the Thevenin voltage (1000/1220)E and two resistors of the same size (330 Ω).
(Actually, the notion that the two resistors form a voltage divider might give you another path to finding the power, particularly since it's a very simple voltage divider with equal value resistors...)
shaltera said:
I=Vth/(Zth+Rl)
Remember: The voltage source Vth sees ONLY the resistances. The reactive (imaginary) part of Zth has "disappeared", cancelling with the reactive part of the load impedance.
shaltera said:
Zth=(330.3+j219)
Zl=(330.3-j219)
I=E(1000/1220)(330.3)
Close. Both the Thevenin and Load resistors are still there. You've only accounted for one of them.
Circuit schematic of a Thevenin equivalent with a sinusoidal source labelled Vth = (50/61)E in series with a 330 ohm resistor and a crossed-out reactive element, feeding a load ZL of 330 with a crossed-out reactive element; red arrow labelled These cancel.
Circuit schematic of a single series loop: a sinusoidal voltage source labelled Vth = (50/61)E on the left, a resistor labelled Rth = 330 across the top, a resistor labelled RL = 330 on the right side, and a blue arrow labelled I showing clockwise current flow.
If you consider the voltage divider created by the two EQUAL resistors, what must be the potential across the load resistor RL?
  • Circuit schematic with a sinusoidal source labelled Vth = (50/61)E, a series impedance Zth containing a 330 resistor and a crossed-out reactance labelled 120, and a load ZL containing a 330 resistor and a crossed-out reactance, with a red dashed note reading These cancel.
  • Circuit schematic of a series loop: a sinusoidal voltage source labelled Vth = (50/61)E, a resistor labelled Rth 330 on the top wire, and a resistor labelled RL 330 on the right side, with loop current I shown in blue flowing clockwise.
