Neutral Conductor Current: How is it Possible?
In a balanced three-phase system, the current through a neutral conductor is theoretically zero because the phase currents (Ia, Ib, Ic) cancel each other out, resulting in Ia + Ib + Ic = 0. This cancellation occurs due to the 120-degree phase separation, which can be visualized through a phasor diagram that shows the vectors returning to the origin. However, in a single-phase residential supply, such as the 230V system discussed, the neutral carries the same current as the phase wire, and thus does not experience zero current. The neutral in this context reflects the imbalance between the two phase wires. Overall, the discussion highlights the differences between three-phase and single-phase systems regarding neutral current behavior.
Manoj Sahu
I read in a book that during normal working condition (balanced system) the current through a neutral conductor is zero i.e., Ia+Ib+Ic =0 where Ia, Ib, Ic are phase current of three different phases a, b, c. How is that possible? I mean if you look at mathematical result of the phases they are parted by 120' each.
In a balanced three phase system, neutral current is always zero.
Plot the phasor diagram and see the resultant. It should be zero.
In your thread title, you've mentioned residential load. Residential supply is single phase supply and the neutral carries the same current as the phase wire.
Likes berkeman
?? How is it possible?" you ask ? Do vectors add head to tail?
Get out your drafting tools and add three of equal length separated by 120 degrees .
You'll wind up back where you started, at the origin 0, 0
within any single branch circuit- jh
On the incoming wires from the pole to the beaker panel , neutral carries the difference between currents on the two phase wires, in other words the imbalance, just as in three phase.
Likes cnh1995
Thanks @jim hardy for that edit.
I was talking about Indian supply system: 230V with one hot and one neutral.
So our residential neutrals never carry zero current.
But as you said, phase and neutral currents are equal indeed "within any single branch circuit".
Ahh that never dawned on egocentric me ! [ Sheepish grin icon ]
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
