Neutron Stars and Special Relativity
Hao
Neutron Stars and Special Relativity and General Relativity
Here is a question which I can't quite wrap my head around:
Suppose we have a Neutron Star that is borderline on the Chandrasekhar limit in its rest frame.
In another frame, the Neutron star is moving.
As a result, its density increases due to
1) Relativistic mass increase.
2) Length contraction.
So why does the Neutron star not form a black hole?
Technically, this question would apply for any object in any frame of reference that is moving sufficiently quickly.
So what am I missing here?
I suppose a general relativistic explanation is that Stress-Energy is a tensor, so matter what coordinate system you use, the criteria for black hole formation will not be met.
So,
1) Is this question well posed?
2) Where does special relativity break down?
3) Did I answer my own question?
4) What is the General Relativistic explanation?
I would like to hear your input.
Thanks.
Yes and yes
For simplicity, consider a spherically symmetric, non-rotating neutron star its rest frame. In this coordinate system, it has a has non-zero stress-energy tensor that satisfies Einstein's equation. Boosting this stress-energy tensor produces a non-zero stress-energy tensor that is also a solution of Einstein's equation, but this boosted solution is not a black hole solution.
Now consider a spherically symmetric black hole in one of the usual coordinate systems. This is a vacuum solution to Einstein's equation, so the stress-energy tensor is identically zero. This stress-energy tensor, too, can be boosted, but the the boost of something identically zero zero is something identically zero. Boosting the stuff on the right side of Einstein's equation results, however, in a "different" looking solution to Einstein's equation, i.e., there isn't a unique vacuum solution to Einstein's equation. In this black hole situation, one of the solutions (unboosted) has (explicit) spherical symmetry and one doesn't (boosted).
Neither of the black hole solutions look like the boosted neutron star solution.
The same considerations apply to rotating neutron stars and rotating black holes. For a synopsis of boosted black holes, see
http://mwrm.wustl.edu/Presentations/akcay_sarp_win.ppt.
"Boosting this stress-energy tensor produces a non-zero stress-energy tensor that is also a solution of Einstein's equation, but this boosted solution is not a black hole solution..."
I don't disagree, but how do we know this is so??
Why did I also get a BBC story at this website about a Sudanese man being forced to marry a goat??
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
