Neutron Stars: Strong Force, Density & Black Holes
Neutron stars are primarily held together by gravity, with the nuclear strong force playing a crucial role in preventing collapse into black holes. The strong force operates at a very short range and does not counteract gravity in the same way as degeneracy pressure, which is responsible for stabilizing white dwarfs and neutron stars. When a neutron star becomes too massive, neutron degeneracy pressure can be overwhelmed, leading to potential collapse into a black hole. The discussion highlights the distinction between attractive forces and the Pauli exclusion principle, which governs particle states. Ultimately, understanding these forces is key to comprehending the lifecycle of neutron stars and their potential transformation into black holes.
Jonny_trigonometry
Is a neutron star held together mainly by the strong force? Are they dense enough so that this is the case, or is gravity the only thing to consider? What about black holes?
Astronomy news on Phys.org
No, it's held together by gravity. The nuclear strong force is pretty much what prevents it from collapsing into a black hole.
huh, now that doesn't make much sense to me. Doesn't the strong force act on any mass, and not care about charge? Therefore, it acts the same way as gravity (bosonic, is that the right word?), but just in a shorter range (10^-15 meters I think). So to me, if the neutron star becomes dense enough so that the strong force would take effect, then the core would pull together and the outside would come crashing into it to make a super dense conglomeration maybe even turning into a black hole...? This way of looking at it simply makes more sense to me.
I just don't see why it would prevent gravity from pulling everything together too much. If it acted in a way as to repel each neutron from the others, then it would prevent gravity from pulling them closer than 10^-15 meters apart, so that if matter was constantly being put into the system, the whole star would have a maximum density for a while until the strong force couldn't repel things enough to overcome gravity and the core would collapse. But this is not how it works as far as i understand.
It is called degeneracy pressure. Electron degeneracy pressure keeps a White Dwarf from collapsing further. Add more mass, and this pressure is "overwhelmed" by gravity and it could collapse to a Neutron star. Then, we have neutron degeneracy pressure. Add more mass and we can collapse to a black hole.
The "Bosonic" fources you refer to are not attractive to where particles can occupy states as described (or excluded) by the Pauli exclusion principle; certain quantum states.
http://en.wikipedia.org/wiki/White_dwarf
http://en.wikipedia.org/wiki/Neutron_degeneracy_pressure
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
