Is Dark Energy the Key to Understanding the Expansion of the Universe?
The Chandra X-Ray Observatory has indicated that galaxies are not accumulating significant amounts of matter over time, suggesting the influence of Dark Energy, also known as Vacuum Energy or Einstein's Cosmological Constant. This implies that large spans of empty space can exert considerable gravitational force, contributing to the universe's ongoing expansion rather than a slowdown. The discussion raises questions about the implications of Dark Energy on the need for Dark Matter and its classification as physics beyond the Standard Model. Additionally, it explores the potential for practical applications of vacuum energy, such as in nano-sized devices, and considers how to compare Dark Energy, Dark Matter, and regular matter in terms of their gravitational effects. Ultimately, the nature of Dark Energy remains speculative, particularly regarding its role in the expansion of the universe.
sanman
The Chandra X-Ray Observatory has revealed that galaxies aren't accumulating lots more matter over time:
http://www.csmonitor.com/2008/1218/p01s07-usgn.html
http://blogs.nature.com/news/thegreatbeyond/2008/12/new_clues_for_dark_energy_1.html
http://blog.newsweek.com/blogs/labnotes/archive/2008/12/16/may-the-dark-energy-be-with-you.aspx
http://arstechnica.com/journals/science.ars/2008/12/17/lighting-up-dark-energy
This is then attributed to the effect of "Dark Energy", more properly identified as Vacuum Energy, or Einstein's Cosmological Constant.
So to me, this means that not only can a large mass have significant gravitational force, but even a large span of empty space can have a large gravitational force associated with it.
So how can we then make use of this knowledge?
I recognize that one practical implication is that the universe is not slowing down in its expansion, but could keep going indefinitely.
And then what?
I remember some experiment by researchers at UC Riverside, showing that the Casimir Effect from vacuum energy could be turned into a nano-sized spring-device. They had 2 corrugated surfaces placed close to each other, at some miniscule separation distance, and the Casimir Effect caused the apparatus to behave like a spring.
Is Dark Energy considered to be physics beyond the Standard Model, if it's merely confirming Einstein's original conjecture on the Cosmological Constant?
Also, does this then diminish the need for Dark Matter to explain the observed nature of the universe?
Astronomy news on Phys.org
Its yet another piece of evidence that confirms the now standard lambdaCDM scenario 'the concordance model'. Eg ~74% dark energy, 22% darkmatter and 4% regular visible matter.
Dark energy and Dark matter are both presumably physics beyond the standard model of particle physics.
In which case, what are the speculative conjectures about what's causing the Dark Energy effect? In the case of Dark Matter, we have WIMPs as an imagined animal. What does the Dark Energy consist of?
I'd like to also ask, how can we compare Dark Energy, Dark Matter, and Regular Matter on a common scale? Aren't they all like apples, oranges and grapes?
Is gravity the common means of measurement?
If regular matter and even dark matter exhibit conventional gravity, then what do we call the force shown by dark energy -- antigravity? Is it working to keep matter apart, or is it just working to stretch out the space that lies between matter as much as possible?
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
