Newtonian fluid in compressible flow?
The discussion revolves around the behavior of Newtonian fluids in the context of compressible flow, particularly focusing on how viscosity may vary with temperature and its implications for the definition of Newtonian versus non-Newtonian fluids.
  • Some participants propose that when compressible effects are considered, viscosity should vary with temperature, questioning whether this violates the definition of Newtonian fluids.
  • Others argue that shear stress remains linearly proportional to strain rate through viscosity, even if viscosity is not constant, and that significant changes in viscosity due to temperature require high Mach numbers.
  • A participant suggests that if viscosity becomes a function of strain rate, it would classify the fluid as non-Newtonian.
  • It is noted that many fluids, including heavy oils, can have temperature-dependent viscosity while still being classified as Newtonian, as long as viscosity does not vary with strain rate.
  • Participants highlight that the definition of Newtonian fluids focuses on the linear relationship between shear stress and strain rate, without specifying conditions related to temperature or density.
Participants express differing views on the implications of varying viscosity with temperature for classifying fluids as Newtonian or non-Newtonian. There is no consensus on whether temperature-dependent viscosity inherently leads to non-Newtonian behavior, as some maintain that it does not if strain rate remains constant.
Participants discuss the nuances of viscosity behavior in relation to temperature and strain rate, indicating that definitions and classifications may depend on specific conditions and assumptions that are not fully resolved in the discussion.
charlies1902
When compressible effects are accounted for, viscosity should vary with temperature.
Doesn't this violate the concept of Newtonian fluids, where shear stress is linearly proportional to the strain rate?
No. The shear stress is still linearly proportional to the strain rate through the viscosity. It's simply the case that viscosity may not be constant. That said, viscosity varies quite slowly with temperature so the Mach number has to be relatively high to start getting the kind of heating required for the effect to be all that noticeable.
Oh, so if the viscosity becomes a function of the strain rate. In that case, it would violate Newtonian fluid?
Yes. We call such fluids non-Newtonian fluids.
Incidentally, for liquids, the viscosity varies pretty rapidly with temperature. Typical values are a few percent per degree C.
Chet
Chet
But even if the viscosity varies with temperature, it doesn't necessarily mean it is a non-Newtonian fluid right?
As long as the viscosity does not vary with the strain rate, the shear stress is still a linear function of the strain rate, even if the viscosity is varying with other parameters?
There are all sorts of fluids where the viscosity varies with temperature and these fluids are Newtonian. Many heavy oils are heated to make them easier to pump by reducing their viscosity.
Remember, the definition states that the shear is linearly proportional to the strain rate. The definition is silent on whether temperature is considered. It's also silent on whether density makes a difference: there are relatively light Newtonian fluids and relatively heavy ones.
Right (like SteamKing said).
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 35 ·
