What Happens if Masses are Negative in Newtonian Potential?
jack7992
Imagine that you have two particles with masses m and M, interacting with the standard Newtonian potential V=-G*m*M/r . When both masses are positive, you have a textbook example of central force motion. What happens if masses are negative? Discuss the cases 1) m<0, M<0; 2) m>0, M<0, m>|M|; 3) m>0, M<0, m<|M|; and 4) m>0, M=-m respectively.
I was planning on just doing more of a analytic approach versus a computational, but my professor want's me to solve it explicitly, and I'm not to sure how to do that. Any hints for just one of the cases would be great!
So, note that the Electro-static potential is V=-kqq'/r
Here q and q' can be either positive or negative. So...try to see some analogy with that maybe? k->G, q->M, q'->m.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
