Newton's Law of Cooling and Resonance Phenomena
The discussion focuses on determining the natural frequency of water molecules using Newton's law of cooling and resonance phenomena. The natural frequency refers to the frequency at which a system oscillates without external forces. Calculating this for a single water molecule at 25 °C and 1 atm is complex, as it typically requires quantum chemistry methods or simplified models. The conversation highlights that discussing a single molecule in this context may not be meaningful. Ultimately, the approach to finding vibrational frequencies must consider the limitations of molecular behavior under specified conditions.
Gh. Soleimani
Can we find the natural frequency of water's molecules by using of Newton's law of cooling and resonance phenomena?
Please define "the natural frequency" of a molecule of water.
Natural frequency is the frequency at which a system tends to oscillate in the absence of any driving or damping force. Free vibrations of an elastic body are called natural vibrations and occur at a frequency called the natural frequency.
Now, assume we want to calculate the natural frequency of a single molecule of water in normal conditions: T = 25 °C and P = 1 atm
What is the procedure of the solution?
For starters, it does not make sense to talk about a single molecule at a given temperature and pressure.
If you are talking about about the vibrational frequencies of a molecule, then you would have to do quantum chemistry calculations or use a simplified mass-and-spring model.
But I have the feeling that this is not what you are after.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
