What Happens to Acceleration When Two Equal Masses Attract Each Other?
  • Thread starter Thread starter Nissan
    Gravity Laws
Newton's law of gravity, expressed as F = Gm1m2/r^2, indicates that the acceleration due to Earth's gravity is 9.8 m/s². When considering two objects with equal mass, each would exert a gravitational acceleration of 9.8 m/s² on the other, but this does not result in a "total acceleration" of 19.6 m/s². Instead, while both objects attract each other, the acceleration experienced by each remains 9.8 m/s². The Earth and a person attract each other with equal force, but due to the Earth's much greater mass, the resulting acceleration of the Earth is negligible. This principle applies primarily to objects in free fall, as standing on the Earth means there is no relative acceleration despite the mutual attraction.
Nissan
I was thinking about Newton's law of gravity:
F = Gm1m2/r^2.
with this law we can see that the acceleration of on object in Earth is (G*mass of the earth) which is 9.8N.
what happens if we cosider in our equation abody which his mass is equvalnce to the mass of the earth?
each object will give the other an acceleration of 9.8N, does it mean's that the total acceleration would be 19.6N? does that mean's that we attract the Earth as well in a fixed acceleration?
Look at the equation again. (m2...)
F = Gm1m2/r^2.
Your post is simply incomprehensible. The acceleration is not measured in N (Newtons), but in \mbox{m s}^{-2}.
Daniel.
Good catch, Dexter. I've never used Newtons for anything, so I didn't know what that N meant. :redface:
(Seriously... I never heard of a Newton until I got onto PF. I still don't know what it is. Everything that I've ever done was in Watts, Foot-pounds, psi, etc..)
In addition, there is no such thing as "total acceleration". If two objects were the same mass and at a distance such that the acceleration was 9.8 meters per second squared, the each would be attracted toward the other at 9.8 meters per second squared. You could then calculate that the distance between them was decreasing at a rate that was increasing at 19.6 meters per second squared but that would not be an "acceleration" of any object.
To answer your last question: yes, we attract the Earth at a fixed acceleration. Since "we" attract the Earth with the same force as that the Earth applies to the object, but the Earth is much more massive than "we" are, that fixed acceleration is unmeasurably small.
This applies, of course, only to objects in free fall. If I am standing on the earth, the Earth and I attract each other with the same force, but there is no acceleration.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
