Why does a skateboard move backward when you push on it, but the Earth does not?
When you push down and back on a skateboard, it moves backward due to Newton's third law, which states that for every action, there is an equal and opposite reaction. The Earth also experiences this force when you step on it, but its massive size—approximately 6 million billion billion times that of a skateboard—means it moves imperceptibly. The skateboard's smaller mass results in a more noticeable backward motion. The discussion emphasizes understanding the relationship between force, mass, and acceleration, as described by the equation F=ma. Ultimately, the exercise encourages learners to articulate these concepts in their own words to deepen their comprehension.
LindaJalie
Use Newton's to explain :
When you take a step, you push down and back on the Earth and the Earth pushes up and forward on you. When you step on a skateboeard, the skateboard moves backward as you push down and back. Why does the skateboard move backward while the Earth does not even if the force is the same?
What makes you think the Earth doesn't move?
How much more massive is the Earth than a skateboard?
DaveC426913 said:
It does. But the Earth masses as much as 6 million billion billion skateboards. It moves one 6 million billion billionths as much.
Could you explain why ? I need details for this answer
Sorry. I went back and edited my answer once I realized that this is a homework question.
If you are studying Newton, you are familiar with F=ma?
I need to explain details for this question
Could you explain why ? I need details for this answer.
... I need to explain details for this question
It would defeat the point of the exercise if any of us provided you with a detailed answer.
You have to provide the details yourself.
But the start has been given to you. The questions are there to guide you.
If you try to walk on a wheeled platform, i.e. the skateboard, the platform goes backwards over the ground ... why does it do that? Can you tell us in your own words?
If you walk on the Earth ... you have to push on the Earth. The Earth is just another mass ... what happens to masses when you push on them?
Likes LindaJalie
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
