Newton's second law and Springs
The discussion explains how to apply Newton's second law, F = ma, to springs despite the non-constant nature of spring force, F = -kx. It emphasizes that varying acceleration can be addressed by solving the second-order differential equation derived from the spring force equation. The potential energy of the spring is given by v(x) = (1/2)kx², and the relationship between force and acceleration is established through F = -kx(t) = m(d²x/dt²). The solution to this differential equation allows for the determination of the position function x(t), which is expressed as x(t) = x₀cos(ωt + φ), with ω² = k/m. Understanding these concepts is crucial for analyzing the dynamics of spring systems.
gkangelexa
Spring Force is F = -kx
So, because the force is not constant, the acceleration is also not constant..
How then can we apply Newton's second law: F = mass x acceleration to springs?
Science news on Phys.org
There is no restriction that Newton's second law must have constant acceleration. You can have a varying acceleration and if you solve F = m\frac{\mathrm{d} ^{2}x}{\mathrm{d} t^{2}} you can get the resulting varying force. For a spring, the potential is v(x) = \frac{1}{2}kx^{2} and F = -\frac{\partial V}{\partial x} = m\frac{\mathrm{d} ^{2}x}{\mathrm{d} t^{2}} so m\frac{\mathrm{d} ^{2}x}{\mathrm{d} t^{2}} = -kx. Acceleration doesn't have to be a constant; it could be given as some varying function of time and the varying spring force would follow suit.
We note that acceleration is the second derivative of the position function. Our position function is x(t), so that v(t)=dx(t)/dt and a(t)=dv(t)/dt. Now Newton's law tells us:
F=-kx(t)=m\frac{d^2 x(t)}{dt^2}
Which is a second order differential equation that we have to solve (we need 2 initial conditions to completely solve this).
F=-kx(t)=m\frac{d^2x(t)}{dt^2}
If you were to bring the mass on the spring to an initial displacement and let it go, you could figure out the position function x(t) by solving that differential equation:
x(t)=x_0~cos(\omega t+\phi )
Where:
\omega^2=\frac{k}{m}
makes sense thanks!
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
