Newton's Second Law: Combined Masses
The discussion centers on calculating the tension in a thread connected to a block on a frictionless table and a 1.0 kg load. The acceleration of both the block and the load is given as 2.0 m/s². The initial calculation for tension resulted in T = 8 N, and the mass of the block was found to be 4.0 kg using the equation T = ma. A correction was suggested regarding the mass of the block, noting that if gravitational acceleration is rounded to 10 m/s², the mass is 4 kg, but using 9.8 m/s² gives a mass of 3.9 kg. The methods used for the calculations were affirmed as correct, with a minor adjustment needed for accuracy.
Peter G.
A block sits on a horizontal frictionless table. A thread attached to its runs horizontally to a pulley at the edge of the table, passes over the pulley and supports a load of 1.0 kg. The size of the acceleration of both the block and the load is 2.0 m/s.
Find the tension in the thread:
To answer this, I used the load:
Acceleration was downward so weight must be greater than tension, thus:
W - T = ma
10 - T = 1 x 2
10 - 2 = T
T = 8
Now use the Free Body force diagram for the block to find the mass of the block:
F = ma
T = ma
8 = 2m
m = 4.0 kg
I'm not sure if my methods are correct, anyone can help me please?
Thanks,
Peter G.
Your methods are very good. But since you rounded off g to 10 m/s^2, the mass of the block on the table should be 4 kg, not 4.0 kg. If you used g = 9.8 m/s^2, then m = 3.9 kg.
Ah ok, thanks a lot PhanthomJay. :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
