Newton's second law dp/dt version?
The discussion revolves around the momentum version of Newton's second law, specifically the relationship between force, momentum, and derivatives of position and velocity. Participants explore the mathematical expressions and implications of these relationships, including the use of product and chain rules in differentiation.
  • One participant expresses confusion about the momentum version of Newton's second law, questioning the relationship between acceleration and the second derivative of position.
  • Another participant clarifies that acceleration is indeed the second order derivative of position, represented as ##a = \frac{d^2x}{dt^2}##.
  • A different participant summarizes the relationship between force and momentum, stating that ##F = dp/dt## and deriving it from the expression ##F = ma##, assuming mass is constant.
  • One participant applies the product rule to differentiate momentum, leading to the expression ##\vec{F} = m\frac{d\vec{v}}{dt} + \frac{dm}{dt}v##, noting that if mass is constant, the second term vanishes.
  • Another participant reflects on the differentiation process, discussing the interpretation of the second derivative and correcting their earlier mention of the chain rule to the product rule.
Participants do not reach a consensus on the interpretation of the derivatives involved, and there are varying levels of understanding regarding the application of differentiation rules. Some participants clarify points while others express confusion, indicating that the discussion remains unresolved.
There are limitations in the discussion regarding the assumptions made about mass being constant and the application of differentiation rules, which may affect the interpretations presented.
Steve Drake
Hello,
I am confused by the momentum version of Newtons second law...
So we know
[tex]\bar{F}=m\bar{a}=m\left(\frac{d\hat{v}}{dt}\right)[/tex]
and that
[tex]\bar{\rho}=m\bar{v}=m\left(\frac{d\bar{x}}{dt}\right)[/tex]
so is
[tex]\frac{d\bar{p}}{dt}=m\frac{d\left(\frac{d\bar{x}}{dt}\right)}{dt}[/tex]
What I mean is this bit [tex]\frac{d\left(\frac{d\bar{x}}{dt}\right)}{dt}[/tex] somehow equal to [tex]\bar{a}[/tex]
Thanks
Science news on Phys.org
Yes, since acceleration is the (first order) time derivative of velocity and velocity is the (first order) derivative of position, the acceleration is said to be the second order derivative of position, which can be written as ##a = \frac{d^2x}{dt^2}##
You can read more about other notations for higher derivatives on [1]
[1] https://en.wikipedia.org/wiki/Derivative
Force F = dp/dt, this result summarizes Newton's first/second law, to prove this, we know that F = ma = m*dv/dt, mass is invariant so we can treat it as a constant, which yields to m*dv/dt = d(m*v)/dt = dp/dt, If no force is acting on an object F = 0 = dp/dt, p is constant from which it follows Newton's first law and momentum conservation, Good luck :p
Steve Drake said:
Hello,
So we know
and that
Using the product rule:
[tex]\vec{F} = \frac{d\vec{p}}{dt}=\frac{d}{dt}(m\vec{v}) = m\frac{d\vec{v}}{dt} + \frac{dm}{dt}v[/tex]
If m is constant, dm/dt = 0 so:
[tex]\vec{F} = m\frac{d\vec{v}}{dt} = ma = m\frac{d}{dt}v = m\frac{d}{dt}(\frac{d\vec{x}}{dt})[/tex]
AM
Thanks guys, forgot about the chain rule for differentiation.
So in general, whenever there is a [tex]\frac{d^{2}}{dx}[/tex] then it can be thought of two separate derivatives, each giving their own result. But the [tex]^2[/tex] means it skips the first result and we go right to the second?
Actually, I misspoke. It is the product rule not the chain rule. I have corrected the error.
The ##\frac{d^{2}x}{dt^2}## signifies the second derivative with respect to time - the derivative with respect to time of (the derivative with respect to time of x).
AM
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 23 ·
