Newton's Second Law finding value of force problem
To determine the force exerted by a soccer ball of mass 0.5 kg kicked at 14 m/s upon hitting a rock for 0.18 seconds, the momentum and time relationship is used. The momentum is calculated as 0.5 kg multiplied by 14 m/s, resulting in 7 kg·m/s. The force is then found by dividing the momentum by the time of contact, yielding approximately 38.9 N. It is clarified that force represents the change in momentum per unit time, which aligns with the scenario since the ball's velocity becomes zero upon impact. This approach effectively solves the problem using the principles of Newton's Second Law.
goomer
If a soccer ball of mass 0.5 kg is kicked with a speed of 14 m/s and hits a rock and is in contact with it for 0.18 seconds, with what force will it hit?
Fnet = ma
I have no idea what to do to get the acceleration for the above formula. It can't possibly be just 14/0.18 can it?
Force can also be defined in terms of momentum and time. What is it, and can you use that in this problem?
Oh I see, so:
Force = Momentum/Time
Momentum = Mass * Velocity = 0.5 kg * 14 m/s = 7
Force = 7/0.18 s = 38.9N right?
goomer said:
Oh I see, so:
Yep! :approve:
Force is actually the change in momentum per unit time. But since the ball was in contact with the stone for that time, and its velocity was zero then, your equation worked out.
Thank you so much for your help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
