Newton's Second Law Integral Form
The discussion focuses on understanding the integral form of Newton's Second Law as applied to fluid dynamics, specifically regarding control volumes (CV) and control surfaces (CS). The first equation presented relates the sum of forces to the change in momentum within a control volume and the flux across its surface. The second equation introduces the velocity of the control volume (u_CV) and its role in calculating momentum changes. Clarification is sought on the distinction between the fluid velocity (u) and the relative velocity (u_rel) in the context of the control volume. The conclusion emphasizes that only the fluid velocity relative to the control volume boundary affects the flux through that boundary.
member 428835
Hi PF!
I was reading my book and I understand the following $$\sum \vec{F} = \frac{\partial}{\partial t} \iiint_{CV} \rho \vec{u} dV +\iint_{CS} \rho \vec{u} ( \vec{u_{rel}} \cdot \hat{n}) dS$$ ##CV## is a control volume, ##CS## is control surface, ##u## is velocity, ##u_{rel}## is velocity relative to control volume, and the rest is self-spoken for. However, then the book states the following $$m_{CV} \frac{d}{dt} \vec{u_{CV}} = \frac{\partial}{\partial t} \iiint_{CV} \rho \vec{u_{CV}} dV +\iint_{CS} \rho \vec{u_{CV}} ( \vec{u_{rel}} \cdot \hat{n}) dS$$ where ##u_{CV}## is the velocity of the control volume. Any help in understanding why this is?
Science news on Phys.org
The first equation looks OK to me if ##u_{rel}## were replaced by just u. In the second equation, I'm not sure what ##u_{CV}## is supposed to represent.
##\vec{u}## is the fluid velocity relative to an inertial frame, while ##\vec{u_{rel}} = \vec{u} − \vec{u_{CV}}## is the fluid velocity relative to the control volume. Then only the fluid velocity relative to the control volume boundary will induce a flux through this boundary. Does that look correct?
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
