Newton's second law - jumping from a height
Bending the knees when landing from a height reduces the impact force experienced by the body. This is because bending the knees increases the time over which the body decelerates, allowing for a gradual change in momentum. According to Newton's second law (F=ma), a longer deceleration time results in a lower average force acting on the body. The discussion highlights that landing with straight legs can lead to greater force and potential injury, whereas bent knees help absorb the impact more effectively. Overall, bending the knees is a crucial technique for safer landings.
eternalronin
When jumping from a height on to a hard surface, it is advisable to bend one's knees on landing. How does bending the knees affect the time one takes to come to rest? (1 mark)
With reference to Newton's second law, explain why it is a good idea to bend one's knees. (2 marks)
F=ma
I'm not quite sure how to answer this question at all...
When landing, you need to change your momentum. What is the relationship between force, time, and change in momentum?
What is the difference between landing with legs straight and landing with them bent (and not held too rigidly) in terms of how forces change over time? Try to sketch a graph. What must the two graphs have in common?
With regards to the second part, you should make sure that you understand Newton's Second Law. More force acting upon a falling body is worse, whereas less force would be better, but how would bending your legs affect that force? Knowing the definitions of each component of F=ma should hopefully make the answer apparent.
Force is equal to rate of change in momentum? f=dp/dt I think. Well I don't know, do bent knees absorb force more? I'll try and draw graphs, thanks
I'm not sure how bending your knees would change the force. Would it decrease it? And since mass stays constant, acceleration would decrease?
If you don't bend your knees it could hurt - why do you think that is?
Here is a fun way to learn:
Try to jump at least 10 times without bending your knees . (Do u experience any agony?)
Repeat the same experiment but this time bending your knees on every jump. (Feel Relaxed ? )
That is, if after jumping fro a height 10 times without bending your knees, you can do the same bending your knees!
I'm not sure where I was going with the 'acceleration would decrease thing' since it's always going to be 9.8, I think
I have an idea, is it because when the legs are bent the angle is different, so the component of the force going downwards is going to be smaller?
And also, when knees are bent it takes a longer time to decelerate, and there would be more displacement as the body is still moving lower. And since it takes a longer time to decelerate to 0, f=ma so the force would be lower?
