Nitinol Current Help | Seeking Advice
  • Thread starter neolin
  • Tags
    Current
In summary, the material Nitinol can be activated using a low voltage DC power supply. It is important not to overheat the wire.
neolin
Hello Members
Im currently working on the material Nitinol, which is a shape memory alloy. Nitionol changes to its permanent trained shape by the addition of heat.
I am currently investigating the effects of Nitinol. In order to heat the Nitinol I plan to use an electric current passing through it. The Nitinol's activating temperature is 70 degrees celsius.
I have extensive material properties of Nitinol and would like some help on determining the current required to heat the material to around 70 degrees.
Thank you Kindly
Any help will be greatly appreciated
neolin said:
Hello Members
Thank you Kindly
Welcome to the PF.
I googled bare wire temperature versus current, and got lots of good hits. I even got an old PF thread that discussed it, and has some links that may be useful:
https://www.physicsforums.com/showthread.php?t=270177
Hi ther. Thanks for your reply. I had a look at them and it looks quite complex. I am having a hard time figuring this out but I will look into it further.
As mentioned as an option in the thread, can you just run some experiments to make your own table of current versus temperature?
From: http://www.nodna.org/product_info.php?language=en&products_id=1493
For example, 400 mA of electrical current through the 6-mil nitinol wire will produce a maximum pull of 11 ounces and full contraction in one second. Reaction time can be faster, in the millisecond range.
To achieve this high current short duration pulses are used.
When doing this consideration must be given to the mass and speed of the material to move.
The faster you move a given mass the greater the inertia that must be overcome.
If the inertia becomes greater than 6 lbs. for the 6-mil wire, it will snap.
From: http://www.imagesco.com/articles/nitinol/06.html
Direct Electrical Heating Nitinol wire can be activated using a low voltage DC (6-12volts) power supply. A simple circuit can be constructed using a battery, switch and a small length of nitinol wire, see figure 7. When activating a Nitinol wire wire using DC current it is important not to overheat the wire by keeping the current on too long. Overheating the Nitinol wire will degrade its properties. DC current doesn't heat the wire evenly. An electrical circuit that uses Pulse Width Modulation (PWM), shown on the next page, heats the wire more evenly and is better for activating Nitinol wire.
Note: For futher info please view the above sites. For extended info, I used the following phrase in GOOGLE:
"activating nitinol electricity" without the qoutes.
Hope this helps.
1. What is Nitinol and how does it work?
Nitinol is a type of shape memory alloy that is composed of approximately 50% nickel and 50% titanium. It works by exhibiting a unique property known as shape memory effect, meaning that it can be deformed at a certain temperature and then return to its original shape when heated above a specific temperature.
2. How is Nitinol used in current help and seeking advice?
Nitinol is commonly used in current help and seeking advice due to its ability to be shaped and re-shaped multiple times without losing its mechanical properties. It is often used in the production of medical devices, such as stents and orthodontic wires, as well as in robotics and aerospace industries.
3. What are the benefits of using Nitinol in current help and seeking advice?
The main benefit of using Nitinol in current help and seeking advice is its shape memory effect, which allows for the creation of devices that can be easily manipulated and re-shaped to fit specific needs. It also has high flexibility and superelasticity, making it ideal for use in delicate and precise applications.
4. Are there any drawbacks or limitations to using Nitinol in current help and seeking advice?
One potential drawback of using Nitinol in current help and seeking advice is its high cost, as it is a relatively expensive material compared to other alloys. Additionally, the shape memory effect can be affected by factors such as fatigue and stress, which may limit its use in certain applications.
5. What is the future of Nitinol in current help and seeking advice?
The future of Nitinol in current help and seeking advice looks promising, as researchers continue to explore new applications and methods for utilizing this unique material. With advancements in technology and manufacturing processes, we can expect to see even more innovative uses for Nitinol in the future.
  • Electrical Engineering
  • STEM Academic Advising
