What Are the Functions and Features of an Oscilloscope?
  • Thread starter Thread starter PainterGuy
    Functions
The discussion revolves around understanding the functions and features of an oscilloscope. Key terms like "TRIG LEVEL," "COUPLING," "HOLD OFF," and the "X-Y" button are highlighted as areas of confusion. The user also inquires about the "VAR SWEEP" function, "EXT TRIG" port, and the "CAL" and "GND" settings. A suggestion is made to refer to a Wikipedia article for comprehensive explanations. The user expresses gratitude and indicates they will seek further clarification if needed.
PainterGuy
hello everyone,
i was able to get a snap of a oscilloscope. please help me know it's functions.
http://img8.imageshack.us/img8/5408/oscillo.jpg
1:- at the top what do "TRIG LEVEL" and "COUPLING" mean?
2:- on the SOURCE switch what do "LINE" and "EXT" mean?
3:- "HOLD OFF" is used to stabalize the signal?
4:- what does "X-Y" button do?
5:- what is function "VAR SWEEP"?
6:- on left side bottom what does "EXT TRIG" port do?
7:- what do "CAL" and "GND" do on right side at bottom?
i am much graful if you can provide me help. many thanks for any help you can provide me.
cheers
painterguy said:
hello everyone,
cheers
The wikipedia article should answer most of your questions. If you have further questions after reading the article, please post them here.
http://en.wikipedia.org/wiki/Oscilloscope
okay. i will try to read this article. will ask you for help.
cheers.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
