No solution to harmonic oscillator
In summary, the lack of a solution when ##k=k_m## is due to the fact that the ##u_n## form a complete set, so there are no other solutions.
Dustinsfl
2,281
Given [itex](\mathcal{L} + k^2)y = \phi(x)[/itex] with homogeneous boundary conditions [itex]y(0) = y(\ell) = 0[/itex] where
\begin{align}
y(x) & = \frac{2}{\ell}\sum_{n = 1}^{\infty} \frac{\sin(k_nx)}{k^2 - k_n^2},\\
\phi(x) & = \frac{2}{\ell}\sum_{n = 1}^{\infty}\sin(k_nx),\\
u_n(x) &= \sqrt{\frac{2}{\ell}}\sum_{n = 1}^{\infty}\frac{\sin(k_nx)}{k^2 - k_n^2},
\end{align}
[itex]\mathcal{L} = \frac{d^2}{dx^2}[/itex], and [itex]k_n = \frac{n\pi}{\ell}[/itex].
If [itex]k = k_m[/itex], there is no solution unless [itex]\phi(x)[/itex] is orthogonal to [itex]u_m(x)[/itex].
Why is this?
Well crunch the numbers - what happens if the condition is not satisfied?
I don't understand what numbers I need to crunch.
For k_m = k_n,
\sum_n\frac{0}{0}\sin(k_nx) = \sum_n\sin(k_nx)
otherwise, k_m\neq k_n
\sum_n\sin(k_nx) = \sum_n\sin(k_nx)
so the DE holds.
We have an indeterminant form on the LHS for the first case and equality for the 2nd. How does orthogonality play a role?
What does "orthogonal" mean?
What does ##k=k_m## mean when you only have ##k_n## in your expressions?
##k=k_m = \frac{m\pi}{\ell}##
##k## is defined in the DE ##(\mathcal{L}+k^2)y = \phi(x)##.
Orthogonal is when the inner product is 0
And ##k_n = \frac{n\pi}{l}## and ##k_{\text{carrot}}=\frac{\text{carrot}\pi}{l}##... I saw... but why the index "m" when index "n" is used in all the relations above?
What does that mean... use words not math?
Similarly for "orthogonal" - what is the relationship between ##u## and ##\phi## when their inner product is zero?
Why is that important to the solutions?
Also curious - how does ##u_n(x)## depend on ##n## when you have it as a sum over all ##n##?
Because it says show that for the case when ##k=k_m## the DE has no solution unless ##\phi(x)## is orthogonal to ##u_m(x)##. The ##k_m## replaces all ##k## so there will be both ##k_m## and ##k_n##.
If there inner product is zero, one of them needs to be a cosine.
I don't mean just say the math in words.
Try to get your head out of the math - this is a physical situation. What is the physical meaning?
I think you need to review the derivation from it's physical foundation. At the moment it seems to be an exercise in abstract mathematics for you.
What is special about ##k_m## is that it is a particular value of ##k##, which is one of the ##\{k_n\}## ... which means that one of the terms in the sums, the one where n=m, has a division-by-zero problem. That gives a non-physical result - therefore: no solution.
But isn't that a problem? Shouldn't there be some solutions to the situation - after all, you can physically set one up and watch it work away without blowing up or anything? Either the premise the equations were built on is just wrong or there's something else like...
... what if that term where n=m did not exist for some reason? Something like that? Then the problem would never come up.
What roles do ##\phi## and ##u_n## play in the solution?
In what situation would you normally care about their orthogonality?
\begin{align}
\end{align}
Why is this?
Where did your expressions for ##u_n(x)##, ##\phi(x)##, and ##y(x)## come from? As Simon noted, your expression for ##u_n(x)## doesn't make sense. You probably meant, as you wrote in another thread, that ##u_n(x) = \sqrt{2/l} \sin k_n x##. The expression for ##\phi(x)## is clearly not orthogonal to ##u_m(x)##, so I don't see how it relates to your question.
Go back to the beginning. You're trying to solve the differential equation ##(\mathcal{L}+\lambda)y(x) = \phi(x)## where ##\mathcal{L}## is some Hermitian operator. You have solutions ##u_n(x)## to the homogeneous equation ##(\mathcal{L}+\lambda)y(x)=0## that satisfy the given boundary conditions. In the particular case of the linear oscillator, where ##\mathcal{L} = d^2/dx^2## and the boundary conditions are ##y(0)=y(l)=0##, you find that ##u_n(x) = \sqrt{2/l}\sin k_n x## where ##\lambda_n=k_n^2## and ##k_n = n\pi/l##.
One important property of Hermitian operators is that the eigenfunctions ##\{u_n\}## of such an operator form a complete set. This means you can express ##y## as a linear combination of the eigenfunctions, i.e.,
$$y(x) = \sum_n a_n u_n(x).$$ Try doing that for ##\phi(x)## as well and plugging the two expansions into the differential equation with ##k=k_m##.
1. What is a harmonic oscillator?
A harmonic oscillator is a physical system in which the restoring force is directly proportional to the displacement from equilibrium position. It can be described mathematically as a system that exhibits periodic motion with a specific frequency.
2. Why is there no solution to the harmonic oscillator?
The harmonic oscillator has no solution when the restoring force is not proportional to the displacement. This can occur when there is an external force acting on the system or when the system experiences damping, which results in the loss of energy and a decrease in amplitude over time.
3. What are the implications of no solution to the harmonic oscillator?
The absence of a solution to the harmonic oscillator means that the system will not exhibit simple harmonic motion, and its behavior will be more complex and unpredictable. This can make it challenging to accurately model and analyze the system.
4. Can the harmonic oscillator ever have a solution?
Yes, the harmonic oscillator can have a solution when the restoring force is directly proportional to the displacement. This is known as simple harmonic motion and is seen in systems such as a mass on a spring or a pendulum.
5. How is the harmonic oscillator used in science?
The harmonic oscillator is a fundamental concept in physics and is used to study and understand various natural phenomena, such as the motion of atoms, molecules, and celestial bodies. It is also applied in fields such as engineering, chemistry, and biology to model and analyze complex systems.
