Noise in 7-10.5 kHz Range: Solutions Needed
  • Thread starter Thread starter nbo10
    Khz Noise Range
The discussion focuses on addressing noise in the 7-10.5 kHz range picked up by a high gain current to voltage amplifier connected to coaxial cable. The user is currently using op-amps and a low pass filter to manage the noise but seeks to restore bandwidth. Concerns are raised about the amplifier's stability, particularly regarding its ability to handle the capacitance of the coax. The amplifier design includes a two-stage configuration with specific gains, and additional filtering measures have been implemented to mitigate noise. The user emphasizes the importance of maintaining bandwidth while effectively measuring a current of about 1nA.
nbo10
Hi all,
I have a high gain current to voltage amp connected to 2-3 meters of coax which is picking up noise in the 7-10.5 kHz range. Does anyone have any expereince in waht could be the source of this noise? Right now I'm using a couple op-amps and a low pass filter to get the noise to a acceptable level but I would really like to get that bandwidth back. Thanks
Is the amplifier specifically designed to drive the large capacitance of 2-3 meters of coax? It's entirely possible the amplifier is unstable and oscillating in that region of the spectrum.
- Warren
As long as he has his impedances matched the coax should not appear as capacitive. Tell us more please nbo10.
It's a two stage amp.
The first stage has a 100mV/nA gain.
I can't say much about the first stage beacuse they sanded the part number off the opamp and the circuit is kinda small. But I think it is a AD549(inverting) and 100Mohm feedback resistor. I measured the capactance of the coax I'm using and it's around 500pF. The literature from the Amp manufacturer says that in the worst case I would have 100pF at the input.
The second stage is pretty basic. There is a Instrumentation Ampilfer that provides a gain of, 1, 10, or 100. Followed by a OP27 with adjustable gain 0.75-1.25. Followed by a simple RC lowpass filter. Then another OP27.
I put a 10nF cap across the feedback resistor of the first OP27 to help filter the noise. It does an alright job, but I'm worried that I need the bandwidth.
THe current I'm measuring is about 1nA.
Thanks
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
