Non conservative force of a wave on a surfer
The discussion revolves around calculating the work done by the non-conservative force of a wave on a surfer as she accelerates from 1.93 m/s to 12.3 m/s while descending 2.95 m. The initial calculation of work done by the wave resulted in 7424.66 J, but this was deemed incorrect due to the misunderstanding of the energy contributions. The change in kinetic energy is 5334.5 J, while the change in gravitational potential energy is 2092 J, leading to a discrepancy of 3242.5 J. This difference is interpreted as the work done by the wave, highlighting the need to accurately account for energy transformations in the system. The conclusion emphasizes that the wave provides additional energy beyond the surfer's kinetic and potential energy changes.
thatgirlyouknow
A surfer is catching a wave. Suppose she starts at the top of the wave with a speed of 1.93 m/s and moves down the wave until her speed reaches 12.3 m/s. The drop in her vertical height is 2.95 m. If her mass is 72.3 kg, how much work is done by the (non-conservative) force of the wave?
Wnc = Ef-E0
Wnc = .5mvf^2 + mghf - (.5mv0^2 + mgh0)
Wnc = .5*72.3*12.3^2 + 72.3*-9.8*0 - (.5*72.3*1.93^2 + 72.3*-9.8*2.95)
.5*72.3*12.3^2 - (.5*72.3*1.93^2 + 72.3*-9.8*2.95)
5469.1335 - (134.66 + (-2090.19))
= 7424.66 J
This should become negative because the non conservative force is opposing displacement (since the surfer is moving down the wave). However, this answer is not correct. What should be changed?
Increasing velocity from 1.93 m/s to 12.3 m/s represents a change in kinetic energy of 5334.5 J
And the change in height of 2.95 m represents a change in grav. potential energy of only 2092 J.
So from where does the extra energy/work come?
The wave, I suppose... so do I take the total of those two and subtract the number I found?
Well the difference in change in kinetic energy and change in potential energy is 3242.5J and presumably that is work done by the wave.
