Non-Isolated Electronic tranformers w/UL approval?
  • Thread starter Thread starter taharvey
    Electronic
The discussion revolves around the development of a non-isolated electronic transformer intended for configurable AC output between 24VAC and 120VAC, with a focus on achieving UL approval. Key concerns include the necessity of isolation for safety, especially since the output voltage can exceed Safety Extra Low Voltage (SELV) thresholds, which generally cap around 60V. Participants note that while many non-isolated AC-DC converters exist with UL approval, the specific conditions under which non-isolation is acceptable remain unclear. There is a consensus that significant insulation measures are essential for devices exposing users to higher voltages. Ultimately, understanding the UL requirements for isolation and safety measures is crucial for the project's success.
taharvey
I’m looking at a project to make a electronic tranformer for use within a product, and driving its teathered external devices for a control system. I want to make the output AC voltage configurable between 24VAC and 120VAC. This can easily be done with PWM of the AC signal and a feedback path. In its simplest form it is just back-to-back MOSFETs in a AC switch with a little filtering, and the PWM controls.
I’d like to get UL approval on the device. Electronic transformers typically empoly a small transformer for isolation (smaller than typical transformer due to high freq operation). However in this application where 120VAC is an output option, the transformer would be 1:1… and thus be seemingly of dubious value for isolation.
It is not clear when UL requires isolation. There are lots of non-isolated AC-DC converters that are UL approved. I also noticed that there are new rules that allow non-isolated PV inverters that are high-voltage DC-AC connected the mains (high stakes consqeunces).
So the basic questions are:
1. Under what circumstances is non-isolation acceptable to UL?
2. What safty measure would be required for this class of control device?
Welcome to the PF.
The main issue is exposing users to voltages above SELV (Safety Extra Low Voltage):
http://en.wikipedia.org/wiki/SELV#Separated_or_safety_extra-low_voltage_.28SELV.29
The voltage level varies with country, but is generally around 60V. I'm not aware of any devices like you mention here:
"There are lots of non-isolated AC-DC converters that are UL approved."
Can you give specific examples?
You will generally need to have isolation from the AC Mains (which is above SELV) in order to get UL approval. Some systems have exceptions and there are some grandfathered systems, but those exceptions would not seem to apply to your application as described. You will need to do some very good insulating in order to have your secondary 120V running around...
You are apparently too young to remember transformerless ac-dc AM radios. The filaments of the 5 vacuum tubes were in series and connected directly to the 120 volts. The 120 volts was rectified directly by the 35Z5. The power plug (I think) was unpolarized. There was an output transformer, however. See
http://books.google.com/books?id=Lb...QDQ&sqi=2&ved=0CDsQ6AEwAw#v=onepage&q&f=false
Bob S
Yes,
Its very common to have non-isolated AC-DC converter ICs such as this circuit from TI:
http://www.ti.com/lit/an/slyt391/slyt391.pdf
Also there are very simple direct regulation schemes such as this:
http://ww1.microchip.com/downloads/en/appnotes/00954A.pdf
Also there non-isolated PV inverters that have 600 VDC on one side and 230VAC on the other side:
http://www.tsrec.net/sitebuildercontent/sitebuilderfiles/faqstranformerlessinverters.pdf
However I do not know when non-isolation is acceptable and when it is not, and if there are different application classes, and what safety mean are required.
taharvey said:
Yes,
And SELV applies to your links how?
I don't think I ever referred to SELV.
THe question ask only those above: i.e. when is non-isolation is acceptable and when it is not, and if there are different application classes, and what safety mean are required.
For example when is it important to have a isolate AC-DC converter and when is it Ok to be non-isolated.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
31K
