Non-Ohmic Materials: Learn About Vanishingly Small Terms
  • Thread starter Thread starter snatchingthepi
    Materials
Non-Ohmic materials, such as superconductors and semiconductors, exhibit "vanishingly small" extra terms in their conductivity equations, which can be quadratic or cubic. In contrast, traditional Ohmic materials maintain linearity, although slight non-linearities can occur under high current densities due to transient heating effects. Examples of these non-linear behaviors include Voltage Dependent Resistors (VDRs) and Negative Temperature Coefficient Resistors (NTCs), which adjust resistance based on temperature changes. Positive Temperature Coefficient Resistors (PTCs) also demonstrate non-linear characteristics by increasing resistance with temperature. Understanding these nuances in conductivity can enhance the application of materials in electronic components.
snatchingthepi
So I learned today about the version of Ohm's law where
J = \sigma E
and my professor mentioned that some materials (non-Ohmic materials like superconductors) have "vanishingly small" extra terms that are quadratic or cubic. I'm wondering if anyone can direct me to a source (or even just tell me) where I can find out just how small these terms are for Ohmic (linearly conducting) materials.
J = \sigma E
The traditional example of non-ohmic materials are semiconductors and semiconductor junctions. The V-I curve of a p-n junction diode is exponential in nature.
But it sounds like you are asking for examples of slight non-linearities in simple conductors? I suppose if the current density is high enough, the transient heating effects might be considered a non-linearity. But the material is still Ohmic, if you use the resistivity for the temperature at each point in the conductor...
For example, the Voltage Dependent Resistor that we use for damping voltage spikes.
Or the Negative Temperature Coefficient Resistor (NTC)- the resistance decreases when the temperature increases. Since the current through the NTC will generate heat, it can be used to limit "inrush current".
You also have the Positive Temperature Coefficient Resistor (PTC)- the resistance increases when the temperature increases. Since the current through the PTC will generate heat, it can be used to generate a startup-current that gradually decreases (for example if you want to demagnetize an instrument when you turn it on).
http://www9.dw-world.de/rtc/infotheque/electronic_components/fig1521.gif
Thank you both.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
