Non-Stationary State Wavefunction - Normalized? <L^2>? Uncertainty on L^2?
mkosmos2
Consider the nonstationary state:
\Psi = \sqrt{\frac{1}{3}}\Psi_{22-1} + \sqrt{\frac{2}{3}}\Psi_{110}
Where \Psi_{22-1} and \Psi_{110} are normalized, orthogonal and stationary states of some radial potential. Is \Psi properly normalized? Calculate the expectation value of L^{2} and the uncertainty in L^{2} for a particle in this state.
|a_{n_{1}l_{1}m_{1}}|^{2} + |a_{n_{2}l_{2}m_{2}}|^{2} = 1 (1)
&lt;L^{2}&gt; = \int_{all{}\Omega}\Psi^{*}(-\hbar^{2}\Lambda^{2})\Psi d\tau (2)
\Delta L^{2} = \sqrt{&lt;(L^{2})^{2}&gt; - &lt;L^{2}&gt;^{2}} (3)
For the first part, I think it's safe in this situation to use equation (1) where the a_{nlm} terms are the two coefficients in \Psi, but I'm not sure if it applies when the quantum numbers aren't the same for the two stationary states.
For the second part, still not positive, but I think if I use equation (2), the L^{2} operator results in \hbar^{2}l(l+1) coming outside the integral, and because the two states are orthogonal, the integral and therefore L^{2} goes to 0.
The last part has me tripped up the most because I don't know whether L^{2} being zero automatically means the uncertainty is zero, but something tells me it's not that simple.
I'm just fuzzy on a lot of the concepts surrounding this topic so any clarification/confirmation will be much, much appreciated.
Thank you very much for your time, and if these answers are correct, sorry I wasted it :s
-Mike
Ok, for the first part, all you need to know is that the states are orthogonal and normalized. This means
\big&lt; \Psi_{n&#039;l&#039;m&#039;} \big\lvert \, \Psi_{nlm} \big&gt; =\big&lt;n&#039;l&#039;m&#039; \big\lvert \,nlm\big&gt; = 0~~ \text{if}~~nlm=n&#039;l&#039;m&#039;;~1~~\text{if}~~nlm \ne n&#039;l&#039;m&#039;
So for your state, we have
\big&lt; \Psi \, \big\lvert \, \Psi \big&gt; =\bigg( \sqrt{ \frac{1}{3}} \Psi_{22-1}^*+ \sqrt{ \frac{2}{3}} \Psi_{110}^* \bigg)\bigg( \sqrt{ \frac{1}{3}} \Psi_{22-1}+ \sqrt{ \frac{2}{3}} \Psi_{110} \bigg)= \frac{1}{3}(1)+ \frac{2}{3}(1) + \frac{2}{6}(0)\frac{2}{6}(0)= \frac{3}{3} =1
So yes, it is normalized.
L^2 \big\lvert \,nlm \big&gt; = \hbar^2 l(l+1) \big\lvert \,nlm \big&gt;
or
\big&lt;n&#039;l&#039;m&#039; \big\lvert L^2 \big\lvert \,nlm \big&gt; = \big&lt;n&#039;l&#039;m&#039;\big\lvert \hbar^2 l(l+1) \big\lvert \,nlm \big&gt; = \hbar^2 l(l+1)~~\text{if}~ l=l&#039;;~~0~~ \text{if} ~~l \ne l&#039;
so,
\begin{multline}\big&lt;L^2 \big&gt; = \frac{1}{3} \big&lt;22-1 \big\lvert \,\hbar^2 2(2+1) \big\lvert 22-1 \big&gt; +\frac{2}{3} \big&lt;110 \big\lvert \,\hbar^2 1(1+1) \big\lvert 110 \big&gt;\\ = \frac{1}{3} \hbar^2 2(2+1) \big&lt;22-1 \big\lvert \ 22-1 \big&gt; +\frac{2}{3} \hbar^2 1(1+1) \big&lt;110 \big\lvert \, 110 \big&gt; = \frac{1}{3} \hbar^2 2(2+1) +\frac{2}{3} \hbar^2 1(1+1) \end{multline}
and etc. You get the idea. By the way, you need to do NO integration on this problem. That's the beauty of orthonormality.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
