Nonconducting Rod bent into Circle
  • Thread starter Thread starter Soccerdude
    Circle Rod
The discussion focuses on calculating the electric field generated by a uniformly charged nonconducting rod bent into a circle. Key points include determining the electric field at the center of the ring (z = 0) and at infinity (z = ∞), as well as finding the positive value of z where the electric field magnitude is maximized. The relevant equations provided include the expression for the electric field due to a charge element and the linear charge density. The participant expresses uncertainty about how to approach the problem, particularly in deriving the electric field expression. The discussion emphasizes the importance of symmetry in solving the problem.
Soccerdude
Question
A thin nonconducting rod with a uniform charge distribution of positive charge Q is bent into a circle of radius R. The central perpendicular axis through the ring is a z axis, with the origin at the center of the ring. What is the magnitude of the electric field due to the rod at (a) z = 0 (b) z = ∞ (c) In terms of R, at what postive value of z is that magnitude maximum? (d) If R = 2.00 cm and Q = 4.00 μC, what is the maximum magnitude?
dE = (kedq/r2)\hat{r}
λ = Q/Length
Solution Attempt
I'm not really sure how to even approach this problem. I know that E = kzQ/(z2+R2)3/2 but I'm not quite sure how to reach this.
Help is much appreciated.
Part (a) you should be able to figure out by inspection, from symmetry considerations.
For part (b), consider an arbitrary point on the z-axis, and find an expression for the field due to an infinitesimal charge element on the circle. Then integrate. Again, keep symmetry in mind.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
