Nonlinear second order differential equation
mumaga
I am having a problem finding the solution for this eq:
y''(x)+(2/x)y'(x)+(w^2)y(x)=0
I couldn't find examples in the textbook that goes on a similar line, and have been searching the internet as well, but no use. I am thinking of using substitution v=y' but not sure how to do that in the presence of y??
any help would be much appreciated!
Is w a constant? You could always multiple by x and you would have a Cauchy-Euler type.
Yes w is a constant! thank you VERY much Dustinsfl! I am now reading about the Cauchy-euler equations and how to solve them!
very appreciated! :)
ahh, just checked the cauchy-euler equation, and from what i understood it does not apply in this case! as the x is in the denominator and only in the second term!
Multiple by x.
I did, but substituting for trial solutions does not deal to cancelling x, for example y=x^m, you will have x left,,
May be you can try reduction of order.
tried that, no implicit solution,,,
I should point out that this is NOT a "non-linear" equation. It is a linear equation with variable coefficients. The standard method for such equations is to use a "power series"
I would start by multiplying both sides by x, as Dustinsfl suggested, but that does NOT give a "Cauchy Euler equation", we get, rather, xy''+ 2y'+ \omega^2 xy= 0. That is not a "Cauchy-Euler equation" because the coefficient of y'' is x, not x2. We could get that by multipling both sides by x2 but then the coefficient of y is x^2 also.
Because that "1/x" is undefined at 0, and, after multipying by x the coefficient of y'' is 0 at x= 0, x= 0 is a "regular singular point" and should use "Frobenius' method" rather than a regular power seties. That is, we look for a solution of the form y= \sum_{n= 0}^\infty a_nx^{n+ c} where "c" is not necessarily a positive integer (not necessariy an integer).
Differentiating term by term, y'= \sum_{n=0}^\infty(c+n)a_nx^{n+c- 1} and y''= \sum_{n=0}^\infty(n+c)(n+ c- 1)a_nx^{n+ c- 2}
Putting those into the equation, we have
\sum_{n=0}^\infty (n+c)(n+c-1)a_nx^{n+ c- 1}+ \sum_{n=0}^\infty 2(n+ c)x^{n+ c- 1}+ \sum_{n=0}^\infty \omega^2 a_n x^{n+c+ 1}.
The lowest power will occur when n= 0 which would give power x^{c- 1} in the first and second terms, x^{c+1} for the last term. That is, the lowest power wil be x^{c- 1} and its coefficient will be c(c-1)a_0+ 2ca_0= (c(c- 1)+ 2c)a_0= (c^2+ c)a_0= 0. . We could choose values of c so that the first, "i" terms were 0 but, in order to be specific we we choose so that the very first term, a_0 is NOT 0. In order for that to be true we must have c^2+ c= 0. This is called the "indicial equation". Obviously c= 0 and c= -1 satisfy this.
Putting c= 0 and then c= -1 into the equations for the coefficients leads to recursive equations for a_n. Does any of that sound familiar to you?
