Noob in the field -- problems making a solenoid....
A group is attempting to build a solenoid using 22 gauge insulated wire and a 19V, 3.3A laptop charger. They initially used a 1A power supply, which was insufficient, and encountered issues with the solenoid reversing current direction. Suggestions include the possibility of the charger having circuitry that prevents shorting and the need for a resistor in series. However, adding a 1.5-ohm resistor caused the solenoid to stop functioning entirely. The discussion highlights the importance of matching the load resistance to the power supply specifications for proper operation.
Anugrah_kora
Hello.
Me and my friends planned to make a solenoid. We used 22 gauge insulated wire and we used an old laptop charger (19v 3.3A) as the power supply. Earlier we used a power supply of 1A and it wasn't enough. When we connected everything and switched on,we saw the solenoid behaving weirdly . We found out that it was changing the direction of the current flow causing it to act like this. I don't know if it is the charger..
Please can someone help me?
Could it be that the power supply has some circuitry which prevents shorting the output? Maybe you need to put a resistor in series with your solenoid.
Tried adding a 1.5ohms resistor in series but the solenoid ceased to function.. :(
What is the DC resistance of your solenoid? Based on your data the charger needs to have at least 19/3.3 = 6 Ohms load - or 120 feet of 22 Ga ( 22 ga = 0.05 Ohms per foot)...
Likes scottdave
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
