Norm of a vector related to coherent states
JorisL
Hi,
For the past couple of days I've been attempting to derive the equality (for any normalised ##\varphi##)
||(a+za^\dagger+ \lambda)\varphi ||^2 = ||(a^\dagger+\bar{z}a+ \bar{\lambda} )\varphi ||^2 + (|z|^2-1)||\varphi ||^2
First of the summation seemed like a typo. So I first tried to prove this but got nowhere. As such I tried to change it to an equality. ( I entertained this idea because I found, and verified, some other typos in previous equations )Below is an outline of my attempt to derive the second equality (assuming a typo)
Here we consider a system of bosons with only one mode hence ##[ a, a^\dagger ] = 1##.
I expanded the norm as ##||(a+za^\dagger+ \lambda)\varphi ||^2 = \langle (a^\dagger+\bar{z}a+ \bar{\lambda} )\varphi , (a+za^\dagger+ \lambda)\varphi \rangle##
I just cannot get a factor ##|z|^2## out of there. Because the inner product is defined as ##\langle\alpha \psi,\phi\rangle = \bar{\alpha}\langle \psi, \phi \rangle## while ##\langle \psi,\alpha\phi\rangle = \alpha\langle \psi, \phi \rangle##.
So the straightforward way doesn't work. Next I tried to use the first equality.
Lets call the two norms in this equality A resp. B, could I maybe use A-B was my idea.
Because in the text the commutation relations were mentioned which (could) show up directly this way.
I'm not going to write everything I tried (a lot) down here but I tried various tricks etc.
Thanks
Joris
It's a little clearer if you write it in the notation
$$||(a+za^\dagger+ \lambda)\varphi ||^2 = \langle \varphi| (a^\dagger+\bar{z}a+ \bar{\lambda} )(a+za^\dagger+ \lambda)|\varphi \rangle.$$
Then you will see that
$$||(a+za^\dagger+ \lambda)\varphi ||^2 - || (a^\dagger+\bar{z}a+ \bar{\lambda} )\varphi ||^2 = \langle \varphi| [a^\dagger+\bar{z}a+ \bar{\lambda} ,a+za^\dagger+ \lambda]|\varphi \rangle$$
and a bit of algebra on the commutator should lead you to the result.
Thanks I will check this tomorrow since it's late already.
Unbelievable I didn't notice that, guess its one of those case where prolonged staring makes it worse :)
Joris
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
