Understanding Normal Distribution and Calculating Probability for Safe Sailing
The discussion focuses on calculating the probability of Mary and Jon safely sailing their raft without exceeding the weight limit of 170kg. Mary’s weight is normally distributed with a mean of 68kg and a variance of 18^2 kg, while Jon's weight has a mean of 82kg and a variance of 15^2 kg. Their equipment weights are 20% and 50% of their respective weights, which must be factored into the total weight calculation. The formula for combining independent normal distributions is highlighted, emphasizing the need to adjust for the weights of their equipment. Understanding these calculations is crucial for determining the probability of their safe return.
amywilliams99
If anyone could help me with the following Q it would be much appreciated!
Womens weights - N (68kg, (18)^2 kg) Mens Weights - N (82kg, (15)^2 kg)
Mary and Jon are sailing a raft. Marys equipment weights 20% of her weight. Jons weighs 50% of his weight. The raft will sink if the total weight is greater than 170kg.
Compute the probability that they make it home safely. (assume weights of mary and jon are sampled independantly from the relevant distributions?
I am having trouble with how to combine the standard deviations etc. Please help!
If x1 ~ N(m1, s12) and x2 ~ N(m2, s22) then ax1 + bx2 ~ N(am1+bm2, a2s12 + b2s22).
Note, the unit of variance is not kg but kg2.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
