Normal Force at the Bottom of a Track
To determine the normal force exerted by a roller coaster at the bottom of a loop with a speed of 25 m/s, the equation N = m(v^2/r + g) is used, where v is the speed, r is the radius of curvature, and g is the acceleration due to gravity. The radius of curvature is confirmed to be 20 meters, leading to a calculation of 31.25 m/s² for centripetal acceleration, which translates to approximately 3.19g. This results in a total normal force of 4.2mg when expressed in terms of the car's weight. The discussion clarifies the importance of including the correct radius in calculations and converting acceleration to g's for clarity. Understanding these relationships is crucial for solving similar physics problems effectively.
sona1177
If the speed of a roller coaster at the bottom of the loop is 25 m/s, what is the normal force exerted by the car by the track in terms of the car's weight mg?
N - mg =mv^2/r
N=mv^2/r + mg
N=m(v^2/r+ g)
N=m (31.25 + g)
My book says the answer is 4.2 mg. What did I do wrong?
Apparently the radius of cuvature is 20 meters at the bottom of the loop, which you did not state. If so, your answer is correct, but they asled for the answer in terms of mg. Convert 31.25 m/sec^2 to how many 'g's , where g = ?).
PhanthomJay said:
Apparently the radius of cuvature is 2 meters at the bottom of the loop, which you did not state. If so, your answer is correct, but they asled for the answer in terms of mg. Convert 31.25 m/sec^2 to how many 'g's , where g = ?).
The Problem never says that the radius of curvature is 2 meters at the bottom. How did you find that? The problem Only says that the roller coaster includes a vertical circular loop of radius 20.0 meters, which I already took into account into the problem. However, I do apologize for not putting that in the question. 31.25 is 3.19 g's. so that makes m (3.19g + g)=4.2mg. Thank you so much! Now I understand.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 21 ·
