Normal modes of a string thought experiment
A stretched string fastened at one end can develop a standing wave when the other end is moved sinusoidally, but this occurs primarily at the normal-mode frequencies of the string. If the driving frequency does not match these modes, the resulting wave will be a moving wave that is a superposition of the string's normal modes. Shaking the string creates a node at a distance from the hand, exciting a normal mode of a shorter string. The system behaves as a "driven harmonic oscillator," leading to complex wave interactions. Overall, real strings exhibit even more intricate behaviors due to additional factors.
Nikitin
Hey! So If I have a stretched string of length L fastened at one end, and I am moving the other end sinusoidally, will a standing wave appear ONLY if I move the other end with one of the normal-mode frequencies of the string? If not, will the resulting wave be a moving wave which is a superposition of the string's normal modes?
Do it and see :)
Shaking the string from one end is a bit different from plucking it.
You get a node a little distance x from your fingers - and you will have excited a normal mode of a string length L-x which is fixed at both ends. Otherwise you have to move your hand with the frequency of the normal modes of your string (work them out for a string length L with one end free).
When you drive a string like that - the system is a "driven harmonic oscillator" and the solutions can get quite complicated. You can represent the result as a superposition of normal modes - just as the normal modes can be represented as a superposition of traveling waves.
Real strings can get more complicated still.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
