Finding the Normalization Constant for the Hydrogen Radial Wave Function
Patroclus
1. Find the normalization constant for the radial wave function for Hydrogen.
I'm told that C = 1/(24a^5)^1/2
But how do I get that?
2.
n=2, l=1
R(2)(1)=Cr^(-r/2a。)
the integral from 0 to infinity of (x^4 * e^-"alpha"x) = 24 / alpha^5
3. I honestly don't know where to start
Depends what your starting point is.
If you're going from the Schrödinger equation, you can apply separation of variables:
\psi(r, \theta, \phi) = R(r) Y_{\ell m}(\theta, \phi)
and plug this into the time independent wave equation
\left( - \frac{\hbar^2}{2m} \nabla^2 + V(r) \right) \psi(r, \theta,\phi) = E \psi(r, \theta, \phi)
and derive the equation for R(r).
Then if you solve it and impose appropriate boundary conditions, you will find
R_{nl} (r) = \sqrt {{\left ( \frac{2 Z}{n a_{\mu}} \right ) }^3\frac{(n-l-1)!}{2n[(n+l)!]} } e^{- Z r / {n a_{\mu}}} \left ( \frac{2 Z r}{n a_{\mu}} \right )^{l} L_{n-l-1}^{2l+1} \left ( \frac{2 Z r}{n a_{\mu}} \right )
which you can normalise using the properties of the Laguerre polynomials.
If you were looking for something simpler, please give us more information :-)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
