Normalization of a wavefunction problem
hellomister
Normalize sin ((n*pi*x)/L) where x is between 0 and L and n is a positive integer
integral (psi*psi)dx=1
N^2 integral sin ((n*pi*x)/L)dx =1
I don't really understand if this integral is correct, what is the complex conjugate of the wavefunction?
Can i just integrate my wavefunction and say tht is psi*psi?
-N^2 Lcos ((n*pi*x/L))/n*pi=1
I just integrated the wavefunction and then solved for N
The complex conjugate of a real number or function is just that number/function itself. You should be squaring your function. You can't just integrate your function alone, it has to be multiplied by itself.
Ohh, thanks! I was very confused.
So then I would square my function and then integrate and solve for N?
then my normalized wavefunction would be N times the original function?
Yes. I don't know why you have a N squared though. There's no reason for N to be squared. N is just some as yet undetermined constant. Squaring it will just confuse you.
The usual way it's done is you write
\psi_n(x) = N \sin{\left(\frac{n\pi x}{L}\right)
where N is the yet unknown normalization constant. Then you plug this wavefunction into
1=\int_0^L \psi_n^*(x)\psi_n(x) dx
and solve for N. Since both \psi_n^*(x) and \psi_n(x) contain N, you get N^2 in the equation.
Ah right, it's been a while...I suppose N^2 would be appropriate. Otherwise, you'd square-root N. (I always use A instead of N which adds to my confusion...)
Sorry about that, i just saw it in my textbook and copied it down, but Vela's explanation really cleared it up! thanks both of you guys. Sorry I am a newbie when it comes to this stuff... and I'm rusty on math.
Also would you guys know anything about guassian integrals? if i was trying to integrate e^(-2ax^2)?
