I What Does Normalization Achieve in Montgomery's Pair Correlation Conjecture?
  • I
  • Thread starter Thread starter nomadreid
    normalization
Normalization in Montgomery's pair correlation conjecture aims to standardize the spacing between non-trivial zeros of the Riemann zeta function, allowing for easier comparison across intervals. The difference between the two normalization factors arises from their respective mathematical contexts, with one factor focusing on logarithmic scaling and the other on average spacing. The concept of "average" spacing refers to the mean distance between known zeros, but it remains unclear how this average aligns with the provided formulas. The normalization process for the imaginary components of the zeros typically relies on the extensive data of known non-trivial zeros rather than the entire set, which is still not fully understood. Understanding these aspects is crucial for grasping the implications of the conjecture and its mathematical foundation.
nomadreid
In the Wiki article on Montgomery's pair correlation conjecture https://en.wikipedia.org/wiki/Montgomery's_pair_correlation_conjecture, it is stated that the normalized spacing between one non-trivial zero γn =½+iT of the Riemann zeta function and the next γn+1 on the critical strip Re(z)= ½ is
the non-normalized interval length L= (γn+1 - γn) times (ln(z/(2π)))/(2π)) .(*)
Also in the intro it says that it is normalized by
multiplying L times 2π /ln(T). (**)
My questions are very elementary so that I can get started on understanding this; it is not a question about the conjecture or the RH per se.
[1] I am not sure what the normalization is supposed to do: make every interval
0<normalized length <1 ?
[2] I seem to have missed something in the difference between (*) and (**):
they are multiplying by two different factors, one of which is almost the reciprocal of the other. So, why the reciprocal if they want to do the same thing, and one that is answered, why almost the reciprocal (difference of a factor of 2π in the argument of the log)?
[3] Where does this expression come from: both intuitively and mathematically? It looks vaguely like an inverse of the normal function, but not quite.
[4] In the intro the author characterizes this informally as an "average" spacing. Average of what? All spacings between zeros? I am not sure how to match up this "average" with the given formulas.
Thanks.
Mathematics news on Phys.org
Let me make the question simpler: when one refers to normalizing a distribution, one usually means to subtract the expected value of the population from each sample and then divide the result by the population standard deviation. OK, but how does one do this in the case of the imaginary components of the zeros on the critical strip of the Riemann zeta function if one does not know all the zeros? Does one just base it on the millions of non-trivial zeros one already knows? Thanks.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
