How Do You Normalize a Wave Function with Given Boundaries?
darkfall13
[SOLVED] Normalization of wave functions
Mainly my question is that with the normalization of a wave function in quantum mechanics we use \int_\infty^\infty |\Psi(x,t)|^2 dx = 1 and we can solve for a constant we may have been given in the problem.
Determine normalization constant:
\Psi(x) = A\cos{\frac{2\pi{x}}{L}} for \frac{-L}{4} \leq x \leq \frac{L}{4} and \Psi = 0 elsewhere
I'm wondering if I'm given those boundaries because we can replace the infinities in the normal equation with these boundaries or would they be used for something else? Thank you!
Outside those boundaries, the value of \Psi(x) is 0, as is stated in your post.
So, only the part between -L/4 and L/4 will contribute to the integral.
Ah ok thanks!
Be sure to mark down this thread as SOLVED once you've gotten the answer.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
