Normalizing wave function, factor of 2 out
The discussion revolves around normalizing the wave function Ψ(x, t) = Ae^{-\lambda|x|}e^{-i\omega t}. The key point is the calculation of the squared magnitude, where the user initially believes there is a missing factor of 2 in the expression for |\Psi(x, t)|^{2}. It is clarified that the factor of 2 arises from changing the limits of integration from -infinity to +infinity to 0 to +infinity, allowing the use of a definite integral. The model solution was poorly written, leading to confusion, but the user ultimately understands the normalization process. The discussion highlights the importance of careful consideration of integration limits in wave function normalization.
Frinkz
Consider the wave function
\Psi(x, t) = Ae^{-\lambda|x|}e^{-i\omega t}
where A, \lambda and \omega are positive real constants.
Normalize \Psi
\int |\Psi(x, t)|^{2} dx = 1
|\Psi(x, t)|^{2} = \Psi^{*}\Psi
I have a model solution - with a step missing, I think my error is in complex conjugate math...
1, Finding |\Psi(x, t)|^{2}
\Psi^{*}\Psi = (Ae^{-\lambda|x|}e^{i\omega t}) (Ae^{-\lambda|x|}e^{-i\omega t})
= A^{2}e^{-2\lambda|x|}e^{i\omega t}e^{-i\omega t}
= A^{2}e^{-2\lambda|x|}e^{0} = A^{2}e^{-2\lambda|x|}
I think this is where my problem is, I am told that
|\Psi(x, t)|^{2} = 2|A|^{2}e^{-2\lambda|x|}So I am missing a factor of 2?
Is there a complex conjugate rule somewhere I am missing?
your steps looks fine to me, I am not sure from where they got the factor of 2?.. and there is no other complex conjugate rule you miss ..
is their answer says that psi^2 is after obtaining the normalized wavefunction? or is it just the step that follows the one you did ?..
Thanks for checking.
Turns out, the model answers were a bit badly written.
They had put in the factor of two, because the integral was changed from -infinity to +infinity, to 0 to +infinity, so you can make use of a definite integral
\int_0^{\infty} \! e^{-\lambda x} = \frac{1}{2}\sqrt{\frac{\pi}{\lambda}}
That step was just omitted from the solution I was trying to understand, but I get it now :)
Sorry, that was a typo.
Should have been e^(-lambda x^2)
