Not able to fully understand what im reading
  • Thread starter Thread starter hiram_sua
    Reading
hiram_sua
hello everyone, this is my first post on these forums. yesterday i was at the local B&N and bought stephen hawkings "a brief history of time". I've never taken a physics course, though I've wanted to in past semesters(without calculus) but it has always interested me. in the space-time chapter i read about the infamous relativity and twins paradox. what i don't understand is WHY one twin ages more than the other merely by jetting at or nearly the speed of light. I am sure there's an easy answer but being that I've never taken a course of the subject i feel lost. any help is greatly appreciated. thanks in advance
A dumby like me can help dumb down the explanation for you! Basically, one of the problems facing physics around the turn of the 19th/20th century (whichever 1900 was) was how to explain the invariance of maxwells equations. Simply, the laws of electromagneticism said that the speed of light is always 300,000,000 meters per second. The problem with this is simple enough. If you ever driven a car at say, 50mph and shot a gun that fired a bullet at 500mph, you would realize that the bullet, from a person stationary watching the car go by, would see the bullet go 50+500 = 550 miles per hour. The problem here is that this does not work with light. If you traveled say, 100,000 meters per second down a road and sent off a beam of light, you would expect a stationary person to see it go 300,100,000 meters per second but this in fact, is not the case! Such a result disagrees with the idea that the speed of light is always 300,000,000 meters per second.
The way that this was solved was by linking time and space using the "Lorentz Transformations". Simply, they are equations that make velocities never add up to be over the speed of light which is the "speed limit" to the universe. This has to be the case because a famous experiment called the Michelson-Morley experiment showed with good enough accuracy that the speed of light had to be constant.
One consequence of the lorentz transformations is that when you move relative to someone, time slows down for you! The twin paradox is the effects of "Time dilation", which is time slowing down for someone. If you travel near the speed of light, 1 minute for you in a spaceship can be 20 minutes on earth! So you would age 1 minute while people on Earth age 20 minutes.
The equations for time dilation only allow time dilation to become noticable at speeds nearing the speed of light. At low, everyday speeds however, the time dilation becomes insignificant so we simply use everyday Newtonian mechanics.
If Penguino's answer isn't enough of a "why", you may find that there is no "why" that can satisfy you. At some point, we just have to say that it works that way because we observe it to work that way.
So you may want to consider the "why" of Galilean Relativity: why would speeds add linearly (ie, Penguino's bullet from a train example)? You'd probably say that it would make logical sense for the universe to work that way. But logic follows from assumptions and Galilean Relativity follows from assumptions about the universe that we have observed to be incorrect: ie, the assumption that the speed of light is not constant to all observers but varies just like every other speed we measure.
Get your arms around that and the "why?" tends to fall away and be replaced with "that's just the way it works".
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
