Not sure what this problem would be called....
The discussion revolves around a function that calculates the probability of having a certain number of mismatching bits between two randomly generated binary arrays of a specified length. Participants explore the statistical properties of this problem, particularly focusing on the binomial distribution and its application to the scenario described.
  • The original poster seeks to determine the probability of having M or fewer mismatching bits between two N-length binary arrays, noting that their testing suggests a bell curve around N/2.
  • Some participants question the assumptions regarding the probability of generating a "1" and the shape of the distribution curve, suggesting that a bell curve for M or fewer mismatches may not be accurate.
  • One participant proposes simplifying the problem by considering one array as all zeros, thus framing it as a binomial distribution problem related to counting combinations of bits.
  • Another participant draws parallels between this problem and the probability of getting M heads when flipping an honest coin N times, reinforcing the connection to binomial distribution and Pascal's triangle.
  • The original poster expresses gratitude for the insights regarding the binomial distribution and acknowledges the usefulness of simplifying the problem.
There is no clear consensus on the exact nature of the distribution curve or the assumptions regarding the probability of generating bits. Multiple viewpoints and interpretations of the problem remain present in the discussion.
Participants highlight the need for clarification on the probability distribution of the bits and the implications of the assumptions made about the bit generation process. The discussion also reflects varying interpretations of the statistical properties involved.
This discussion may be useful for individuals interested in probability theory, particularly in the context of binomial distributions and their applications in computational problems involving binary data.
Povilas M
Hi,
I am trying to write a function which would take two arguments:
-> number of bits (which are a binary 0 or 1 value) N
-> and acceptable number of mismatching bits M
The function would statistically determine the probability of having M or less mismatching bits when randomly generating two N long bit arrays and comparing them. Difference between 1001 and 1011 would be 1 for example as only the third bit differs. My testing indicates a bell curve is formed around N/2, but I've not done maths for years, it's hard for me to figure the formula out...
Thanks a lot
Hi Povilas:
Your problem statement confuses me a bit.
1. You did not mention what the the probability of generating a "1" is with the bit generator you are using. In the above quote the "N/2" suggests the probability is exactly 1/2, but you did not say that explicitly.
2. You say that your experiments produce a "bell curve", but your description says you want a curve for "M or less mismatching bits". That seems wrong to me since a curve for that result would not be bell shaped. What would be approximately bell shaped is a curve for exactly M matches.
If the "bell curve" you want is for exactly M matches, the answer is a binomial distribution curve. Take a look at
Hope this helps.
Regards,
Buzz
Can you provide a context of where you might use this function?
I was thinking that you could simplify the problem by considering the first N bit array as all zeros and
now you only need to count all the N bit arrays with <=M bits as ones:
Basically its a binomial distribution problem ala pascal's triangle kind of problem:
https://en.wikipedia.org/wiki/Pascal's_triangle
so for a five bit string you'd have:
- 1 string of zeros
- 5 strings with 1 one bit
- 10 strings with 2 one bits
- 10 strings with 3 one bits
- 5 strings with 4 one bitys
- 1 string with all one bits
Hi @jedishrfu:
I am not sure you were asking the question for me to answer, but here it is.
The binomial distribution has many uses. A common example is to calculate the probability of getting M heads when flipping "an honest coin" N times.
This is exactly the same probability of getting M matches (heads and heads or tails and tails) when flipping two "honest coins" M times.
Pascals triangle is a way of calculating the number of combinations of N things when M are of one kind and N-M are of a different kind. This usually noted as
(N over M).​
(Sorry about the awkwardness of the way I show the notation. The Wikipedia citation in post #2 shows it correctly.)
In the quote above I am not sure what "ala" means exactly, but
P(N,M) = (N over M) × (1/2)N,​
where P is the binomial distribution probability when P(1,1) = 1/2, the probability of heads for an "honest coin".
Regards,
Buzz
Thanks all! Binomial distribution curve was exactly what I needed, I figured out the rest from there. Jedishrfu, simplifying the problem was a very useful point as well!
Thanks again!
My context question was for the original poster.
Hopefully, he can tell us more about the problem he's trying to solve.
Thanks again!
So i guess youre not going to tell us the context.
  • · Replies 29 ·
