Novice EE Student Needs Help with Wiring Schematic
  • Thread starter Thread starter eentijdbruik
    Lost
A novice electrical engineering student is struggling with wiring a schematic, particularly understanding the VCC and ground connections. They confirm that VCC should connect to the positive terminal of the power source, while ground connects to the negative terminal. The discussion reassures the student that asking basic questions is normal and encourages them to seek additional resources for clarification. It is noted that in most cases, ground corresponds to the negative terminal, but there are exceptions where this may not apply. Overall, the conversation emphasizes the importance of understanding these fundamental concepts in electronics.
eentijdbruik
I just started a EE class and the teachers just threw up there without really explaining everything. Everyone's lost. I tried to Google, but couldn't find anything.
I have a breadboard, and I have a schematic I need to wire, but I do not really understand how to wire the VCC and ground (symbols). From what I've been told, VCC goes to power source positive, ground to power source negative. Is that right?
I'm sorry for the painfully stupid / obvious questions. Course textbooks come in two weeks and the teachers are overloaded.
It would help you. http://www.kpsec.freeuk.com/docs/breadbrd.pdf"
try this one.http://www.allaboutcircuits.com/vol_6/chpt_2/3.html
Mmhmm.
Don't worry about "noob questions". Everyone has to start somewhere :)
Most of the time with floating power supplies you want ground to be that power source negative. In your case this is probably what you want.
Just be aware that there are cases where ground doesn't mean the negative terminal on a power supply.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
