Number if rational iff it has periodic decimal expansion
Logik
My teacher gave us as excercices this:
Prove that a number is rational if and only if from some point on its decimal expansion becomes periodic.
I'm pretty certain you have to prove it by contradiction, but I don't get how to represent to periodic decimal expension in a proof?
Any hint is welcome, thanks in advance.
First, to show that rational => repeating decimal expansion, remember that long division is how you get from a rational number to its decimal expansion. If r=a/b, then there are only b possible remainders at each step. What happens when the same remainder comes up a second time (after you've gone through all the digits in a)? I'll let you work on the other direction.
Ok well I guess my intuition was bad. I made a few search on books.google.com and found a couple of proofs. One is pretty easy and I actually though of that solutions before but didn't know how to generalise it. My only problem now is that I'm not familiar with one notation in the proofs.
I don't understand the reprensetation of the period, so in this image the first line where it says x= a_n ...
http://img131.imageshack.us/img131/3996/proof2or5.jpg
each ai is a non repeating digit of the number; each ci is a digit of the repeating part of the number. So, for example
1.1234343434...
a0 = 1
a-1 = 1
a-2 = 2
c1 = 3
c2 = 4
m=2
Thanks... that was kinda easy but I guess you just need to know it. Btw good job, this forum is a great ressource :P
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
