Number of ways to fill 3 boxes with 5 balls
  • Thread starter andyrk
  • Tags
    Balls
In summary, when filling 3 different boxes with 5 different balls, with one box receiving 3 balls and the other two receiving 1 ball each, there are 60 possible ways to do so. This is calculated using the rule of product, where the number of ways to pick 3 balls out of 5 is multiplied by the number of ways to pick 1 ball out of 2, and then multiplied by the number of permutations of the boxes. The correct representation is 5!/(3!1!1!) x 1/2! x 3!, which accounts for the different arrangements of the boxes. Additionally, this problem uses the rule of product because each choice of balls affects the number of choices for the remaining
andyrk
658
What are the number of ways in which 3 different boxes can be filled with 5 different balls so that one box gets 3 balls and the other two get 1 ball each? Each box has the capacity to hold 5 balls at most.
The answer to this is 5!/(3!1!1!) x 1/2! x 3! = 60
But when I do it, I think of it this way- (Number of ways to chose 3 balls out of 5) x (Number of ways to chose 1 ball out of 2) x (Number of permutations of boxes) = C(5,3) x C(2,1) x 3! = 5! = 120.
But this is wrong as one can easily see. So how do I go about the right way?
Mathematics news on Phys.org
Rule of product
First, determine how many possibilities there are to pick 3 different balls for one box - C5,3 - 10 ways.
Apply rule of product - for 3 different boxes: 30, as for each individual box there are 10 ways.
The remaining 2 balls just have 2 possibilities for each previous setup you considered - 30 x 2 = 60.
Your method almost hits home, but when you calculate permutations of boxes, you are counting the same thing too many times. Not ...x 3!, but just .. x 3. It is here where you violate the rule of product.
3! means something like this: You have calculated all the possibilities to set up 3 boxes as requested, BUT now you don't merely count them all together, but you are also considering their ordering and that is not demanded in the problem statement.
Also, do you understand why the word "different" is used to describe the balls and boxes?
nuuskur said:
Rule of product
Oh yeah. I got that now. Thanks for the help. But could you explain how it got represented in the form 5!/(3!1!1!) x 1/2! x 3! = 60? I have the way to answer the question but I am just concerned about how it got represented like that?
Also, on your reasoning as to why 3 would be used in place of 3!, shouldn't it be 3!? That is because after we have selected the balls we now need to select the boxes for them. So let's label the set of 3 balls we selected as A and the other one ball as B and the last one ball as C. Then A has 3 options to be put and B has 2 options to be put and finally C is left with only 1 option. So shouldn't it be 3 x 2 x 1 = 3!? and not 3 in the end and so shouldn't the answer be 120?
Did you mean "the set of 3 boxes" ?
Label the balls as 1,2,3,4,5 and the boxes as A,B,C.
The assignments
A: 1,2,3 B: 4 C:5
A: 1,2,3, C: 5 B:4
are not distinct assignments. They would be counted as distinct assignments if you imagine picking distinct groupings of balls and laying the groups out in order on table ( 3 balls, 1 ball and 1 ball) and then assigning the boxes to the groupings. The two groups of 1 ball cause a problem in that method of counting. You could correct your answer by dividing by (2!).
[itex] C_{n1,n2,n3}^{N} = C_{n1}^N C_{n2}^{N-n1} C_{n3}^{N-n1-n2} [/itex] so your method is the same approach as the book's answer. The book's answer contains the correction factor [itex] \frac{1}{2!} [/itex].
No, I meant set of of 3 balls only.
The assignments
A: 1,2,3 B: 4 C:5
A: 1,2,3, C: 5 B:4
But A:1,2,3 B: 4 C:5
and A:1,2,3 B: 5 C:4
are distinct assignments, right? So That's the reason I included 3 x 2 in my answer and not just 3. That's because, the balls 1,2,3 (labelled as set A in my convention) have 3 choices of boxes and then ball 4 (set B in my convention) has 2 boxes to chose from and finally ball 5 (set C in my convention) is left with only 1 box to chose from. So the numbers of ways to populate the boxes such in the ratio of 3:1:1 would be C(5,3) (Number of ways to chose 3 balls from 5) x C(2,1)(Number of ways to chose 1 ball from the remaining 2) x 3! (number of ways to populate/chose the boxes) = 120. But this seems to differ when I compare it with the answer, i.e. 60, which makes me confused as to where did I go wrong?
Yes, they are distinct assignments. However the list:
A:1,2,3 B:4 C:5
A:1,2,3 C:4 B:5
A:1,2,3 C:5 B:4
A:1,2,3 B:5 C:4
contains redundant assignments.
If we have put the balls on a table as (1,2,3) (4) (5) and assign the boxes A,B,C to these groups each assignment of boxes is a distinct way of putting the balls in the boxes.
However when we consider the grouping (1,2,3)(5)(4) and assign the boxes to groups, we duplicate assignments that were made in the previous step.
Right. But my answer doesn't include duplicate answers. The 3! is there because of a reason which I mentioned in Post #7. It doesn't include any duplicate assignments.
In your notation and with your method, some possibilities are:
Groups of balls A = {1,2,3} , B = {4}, C = {5}
Assignment of groups: A in Box 1, B in Box 2, C in Box 3
Groups of balls A = {1,2,3}, B = {5}, C = {4}
Assignment of groups: A in Box 1, B in box 3, C in Box 2
Those two assignments are the same.
Why are they the same? Each ball is different, each box is different so shouldn't the two assignments be different and not the same? Also, how does this account for the fact that 3 should be used instead of 3 x 2 x 1 = 3! in the end of the answer?
In each case Box 2 contains ball 4 and Box 3 contains ball 5.
You put it the wrong way. What I meant was that why is A = 1,2,3 B = 4 and C = 5 the same as A = 1,2,3 B = 5 and C = 4?
Here A,B,C are boxes and 1,2,3,4,5 are balls.
Those groupings of balls are not the same. I didn't say they were the same.
Okay. But that was what I essentially wanted to confirm. And as it turns out that they are different then what makes the answer have 3 in the end and not 3 x 2 = 3! ??
The assignment of the boxes to the 3 groups of balls must be done for each of those groupings. Assignments of boxes to one grouping of balls duplicates situations reached in assignments of boxes to the other grouping of balls.
But my method doesn't assign boxes to only one group of balls. Its assigns boxes to all group of balls. Then where is the problem?
If you can't see that from post #10, try writing out what your method does for a simpler problem where two boxes have the same number of balls in them.
Okay. So we have 2 different boxes and 4 different balls. And we have to put 2 in each of them. They number of ways to do so would be: C(4,2) (Number of ways to select 2 balls out of 4) x C(2,1) (Number of ways to assign a box to anyone group of balls selected) = 12 ways. That was my method for the original problem too.
Write out the actual assignments. For example 2 balls in 2 boxes with 1 ball in each box.
Balls {1,2}
Groupings
Grouping 1: A= {1} B = {2}
Grouping 2: A = {2} B = {1}
Box Assignments to Groupings:
Box 1 to Grouping 1 A, Box 2 to Grouping 1 B: result is ball 1 in Box 1, ball 2 in Box 2
Box 2 to Grouping 1 A, Box 1 to Grouping 1 B: result is ... etc.
Box 1 to Grouping 2 A, Box 2 to Grouping 2 B:
Box 2 to Grouping 2 A, Box 1 to Grouping 2 B:
Balls {1,2}
Groupings
You're confusing me even more. Isn't there any simpler explanation to why we don't use 3! and instead we use 3?
The usual method of showing a claim is untrue in mathematics is to give a counterexample. If you work out a detailed counter example, perhaps you can explain to yourself where your method goes wrong.
I just got the answer on working it out with examples. Thanks :)
1. How many ways can 3 boxes be filled with 5 balls?
There are 10 possible ways to fill 3 boxes with 5 balls. This is calculated by using the combination formula nCr, where n is the total number of objects and r is the number of objects being chosen.
2. Is there a specific pattern or formula to determine the number of ways to fill 3 boxes with 5 balls?
Yes, the formula to calculate the number of ways to fill r objects into n boxes is n^r. In this case, 5 balls are being placed into 3 boxes, so the formula would be 3^5 = 243.
3. What if there are more than 5 balls, how would the number of ways to fill 3 boxes change?
If there are more than 5 balls, the number of ways to fill 3 boxes will increase. The formula to calculate the number of ways would still be n^r, but the value of n (total number of objects) would be larger.
4. Can the number of ways to fill 3 boxes with 5 balls be calculated using permutations instead of combinations?
No, permutations are used when the order of objects matters. In this case, the order of the balls in the boxes does not affect the number of ways they can be arranged, so combinations must be used instead.
5. Are there any practical applications for understanding the number of ways to fill 3 boxes with 5 balls?
Yes, this concept is commonly used in probability and statistics. It can also be applied in real-life scenarios such as filling different sized containers with a specific number of objects, or organizing items into different groups.
  • General Math
  • General Math
