NVT/NPT Monte Carlo Simulation - Thermodynamics Explained
  • Thread starter Thread starter pyscho
    Monte carlo
pyscho
Hello,
I am working on a MC simulation of a solid using NVT ensemble with Metropolis algorithm. The botlzman factor is of the form exp(-βΔU(r1,r2...rN)), where U is just the potential energy.
From thermodyanmics, dU=dq+dw (dq is the amount of heat put in, and dw is the amount of work done on the system). Since there is no work done (constant volume). dU=dq. Therefore this factor makes sense to me.
Now what I would like to do is let the volume change under constant pressure and temperature. That requires NPT ensemble. Again from thermodynamics du=dq+dw, but since volume is changing, dU=dq-pdV=dq-d(pV), thus d(U+pV)=dq. That's the enthalpy. What I would expect the boltzman factor to be is exp(-β(ΔU+pΔV)). Am I thinking wrong? However, I found it to be in the form exp(-β(ΔU+pΔV-NkTln(V'/V)) where V'=V+ΔV. Where does this extra term come from!?
Thank you very much for your help.
pyscho said:
Hello,
I think,in this case dU has been take into two parts:
1.ΔU;that is an internal interaction change of energy,and
2.PdV-TdS;that the exra term which u see is TdS=nkTln(V'/V)
maybe!?
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
